Closed Thread
Old 17-08-2020, 04:23 PM   #5401
russellw
russellw's Avatar
Default Re: Covid 19 -
Originally Posted by Romulus View Post
If it weren't for a car crash or Covid, a patient with a terminal co-morbidity is likely to cross the rainbow bridge sooner rather than later. CV-19 is forcing those with co-morbidities to cross that bridge sooner.
The bit in italics is correct and that is why it should properly be recorded as the cause of death and it frankly doesn't matter if it's one day less than they would otherwise have had or years.
Some countries (notably the UK) have decided to ignore the international guidelines and as a result the number of reported deaths dropped by about 3k a a couple of days ago after they reclassified some deaths to other causes.
That is manipulation of the data. If everyone sings from the same hymn sheet then we end up with directly comparable statistics but if some countries start doing their own thing in order to make the data more palatable then we lose consistency in the data models.
The WHO also issues a separate set of guidelines for classification of COVID19 to ensure consistency in the data. In short, these guidelines state: (the emphasis is mine)
A death due to COVID-19 is defined as a death resulting from a clinically compatible illness, in a probable or confirmed COVID-19 case, unless there is a clear alternative cause of death that cannot be related to COVID disease (e.g. trauma). There should be no period of complete recovery from COVID-19 between illness and death.
A death due to COVID-19 may not be attributed to another disease (e.g. cancer) and should be counted independently of pre-existing conditions that are suspected of triggering a severe course of COVID-19.
The current form for recording a death that is used for global reporting of all morbidities has multiple lines to record the 'cause' with the main cause on the last line and 2 sections.
Line 1: Report disease or condition directly leading to death
This is used to identify the specific diagnosis that caused the death - e.g pneumonia or ARDS.
Lines 2 onwards: Report chain of events in due to order (if applicable)
So in a COVID19 case we might have the following:
Line 1: ARDS
Line 2: (due to) Pneumonia
Line 3: (due to) COVID19
The second section is used for recording co-morbidities:
2. Other significant conditions contributing to death (time intervals can be included in brackets after the condition)
russellw is offline
Old 17-08-2020, 10:16 PM   #5402
Franco Cozzo
Franco Cozzo's Avatar
South Australia welcoming foreign students back to university but no Mexicans across the border, I see how it is
Franco Cozzo is offline
Old 17-08-2020, 10:30 PM   #5403
Mr_G6ET
Ford G6ET FG MkII
Mr_G6ET's Avatar
The 'mexicans' don't contribute money, just spread germs
Mr_G6ET is offline
Old 17-08-2020, 10:34 PM   #5404
Fordman1
Fordman1's Avatar
Neither do Wackos that spread conspiracy theories.
Sound familiar?
Fordman1 is offline
Old 17-08-2020, 10:39 PM   #5405
Mr_G6ET
Ford G6ET FG MkII
Mr_G6ET's Avatar
Sound familiar?
i feel ok that you are likely referring to the sovereign citizens.... from Victoria
Mr_G6ET is offline
Old 17-08-2020, 10:45 PM   #5406
Mr_G6ET
Ford G6ET FG MkII
Mr_G6ET's Avatar
[QUOTE= conspiracy theories ?[/QUOTE]
nothing familiar, help me out.
What do think the conspiracy theory is ? Sorry if I missed the msg but I thought NSW was considered to be the 'mexicans'
AS A JOKE FFS
Mr_G6ET is offline
Old 18-08-2020, 12:20 PM   #5407
russellw
russellw's Avatar
272 new cases for Australia and 25 deaths sees the CMR rise to 1.787% although active cases drop to 8,599. NSW recorded 7 cases, SA recorded 1 with the balance in Victoria. The 25 deaths represent the worst day thus far since the pandemic began.
9 new cases and no deaths for NZ so CMR is 1.349% and active cases rise to 78.
The UK had 713 new cases and 3 deaths yesterday for a CMR of 12.960%.
Just over (a much lower) 37.5k new cases in the USA yesterday and 521 deaths sees CMR down to 3.110% and active cases at 44.4% with the raw numbers rising again. Note that the USA is actually minus one day due to time differences.
Other notable points:
The USA completes 71M, UAE 6M and India 31M tests;
Australia's CMR drops below that of both NZ and Russia;
Peru now has the 2nd worst deaths per 100k adults (104.89) behind only Belgium;
Lebanon (456) is the only country torecord a new daily high; those in blue for the second consecutive day and those in red for a third or more consecutive day.
russellw is offline
Old 18-08-2020, 01:01 PM   #5408
russellw
russellw's Avatar
Some of the modelling makes interesting reading.
For example, most models currently have the USA hitting anywhere between 12-20M confirmed infections and 205-250k deaths by the end of October but that is such a wide range as to be almost meaningless.
For what it's worth (frankly not much), my modelling suggests that the number of cases is likely to be somewhat lower than those predictions - somewhere between 7.5-10M with the greater likelihood at the lower end of that range if the current trends hold.
My model is in agreement with the range of deaths although it is likely to be at the lower end of that spectrum (205k) given the recent improvements.
The predictions for Australia are suggesting 1,525 deaths by the end of October but my modelling only has a range of 300-500 with weighting toward the lower end. My case number modelling has an unfortunately wide range due to the Victorian spike so the prediction is anything between 24-36K cases by the end of October.
russellw is offline
Old 18-08-2020, 02:35 PM   #5409
MercuryT
MercuryT's Avatar
Tasmania to keep it's borders shut to at least December 1st...…….
MercuryT is offline
Old 18-08-2020, 06:55 PM   #5410
MercuryT
MercuryT's Avatar
Vouchers up to 100 given out to Tasmanians to encourage travel and help the industry.
Better than nothing and hopefully helps those many struggling businesses
MercuryT is offline
Old 18-08-2020, 07:22 PM   #5411
Tassie f100
AS A JOKE FFS
Pretty sure Victorians were always referred to as Mexicans by the more northern states
Tassie f100 is offline
Old 18-08-2020, 07:33 PM   #5412
DJR-351
I am Groot
DJR-351's Avatar
For as long as i can remember in WA......
McLaren F1
Dick Johnson Racing
"Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe
DJR-351 is offline
Old 18-08-2020, 08:20 PM   #5413
MercuryT
MercuryT's Avatar
All you big islanders are Mexicans! ha
MercuryT is offline
Old 18-08-2020, 08:46 PM   #5414
Mr_G6ET
Ford G6ET FG MkII
Mr_G6ET's Avatar
yes, sorry too many vodkas. Yes Victorians are the mexicans, thx for the clarification and alignment
Mr_G6ET is offline
Old 18-08-2020, 09:59 PM   #5415
And that makes Tasmanians Venezuelans.
marty351 is offline
Old 18-08-2020, 10:50 PM   #5416
PhilT2
Sign up for the vaccine here.
https://www.nucleusnetwork.com/form/...kvJPKAFv8qktuk
I signed up but got rejected; no reason given, just didn't meet criteria. Age maybe.
PhilT2 is offline
Old 19-08-2020, 12:12 PM   #5417
russellw
russellw's Avatar
214 new cases for Australia and 17 deaths sees the CMR rise to 1.842% although active cases drop to 8,406. NSW recorded 3 cases, WA recorded 1 with the balance in Victoria.
12 new cases and no deaths for NZ so CMR is 1.339% and active cases rise to 90.
The UK had 1,089 new cases and 12 deaths yesterday for a CMR of 12.920% although we know they are now not counting their mortalities by the WHO guidelines.
Just over 40.5k new cases in the USA yesterday and 589 deaths sees CMR down to 3.095% and active cases at 44.9% with the raw numbers still rising. Note that the USA is actually minus one day due to time differences.
The USA completes 72M and Belgium 2M tests;
Global cases pass 22M with the last 1M taking 5 days;
Tunisia (129), Albania (155), Nepal (1,016) and Iraq (4,576) recorded new daily highs; those in blue for the second consecutive day and those in red for a third or more consecutive day.
russellw is offline
Old 19-08-2020, 12:12 PM   #5418
Charliewool
Bolt Nerd
Charliewool's Avatar
https://www.theguardian.com/world/20...ne-covid-cases
Pesky New Zealanders!!.... Really need to start taking advice from the man in control!
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is offline
Old 19-08-2020, 12:16 PM   #5419
Mr_G6ET
Ford G6ET FG MkII
Mr_G6ET's Avatar
Originally Posted by Charliewool View Post
....taking advice from the man in control!
Unreal isn't it, another example of when he doesn't know that he sounds like an idiot
Mr_G6ET is offline
Old 19-08-2020, 12:43 PM   #5420
PhilT2
It's not just him.
https://crooksandliars.com/2020/08/a...-my-pillow-guy
PhilT2 is offline
Old 19-08-2020, 12:44 PM   #5421
PooDog
PooDog's Avatar
Yep hes set the example for us .....why dont we learn
Fgx xr8 winter white manual, gone but not forgotten
22 mitsubishi outlander XLS PHEV
Au11 fairmont Ghia ported gt40p heads ,comp springs and locks
Xe 264 cam,custom intake,pacemaker tri y headers
524nm torque
19 Triton GSXR manual
PooDog is offline
Old 19-08-2020, 01:07 PM   #5422
roKWiz
Cabover nut
roKWiz's Avatar
Tierra del Fuego ans
roKWiz is offline
Old 19-08-2020, 01:30 PM   #5423
Franco Cozzo
The thing is most people won't actually fact check what he says and when he's at a rally it's all his supporters anyway who'd just believe it.
The guy is a salesman who happens to be President of the USA, it's not surprising the guy uses sales tactics for everything.
There's 'telling lies' and there's bull****ting, this falls in the latter category and is sales 101.
Old 19-08-2020, 02:27 PM   #5424
T3rminator
T3rminator's Avatar
Has anyone heard of "Plan D"?
Deliberately creating new strains of CV, infecting 30,000 volunteers, so that they can then trial different vaccines?!?!?! Geeeees....what could go wrong?
Are there even labs that can hold that many people? Actually I don't know if I want to know the answer to that.
https://www.washingtonpost.com/healt...llenge-trials/
T3rminator is offline
Old 19-08-2020, 02:46 PM   #5425
PooDog
PooDog's Avatar
Slight correction .......most people should be most mericans
524nm torque
PooDog is offline
Old 19-08-2020, 06:04 PM   #5426
MercuryT
MercuryT's Avatar
It's Paradise here.
Closed borders from all the Mexicans.
Venezuela it is without the weather or crime
MercuryT is offline
Old 19-08-2020, 06:08 PM   #5427
roKWiz
Cabover nut
roKWiz's Avatar
Originally Posted by MercuryT View Post
It's Paradise here.
Or money in the long run.
roKWiz is offline
Old 19-08-2020, 06:42 PM   #5428
CoupeKing
It's Paradise here.
Sounds like one big happy family.
CoupeKing is offline
Old 19-08-2020, 07:25 PM   #5429
Jack91
Jack91's Avatar
We will survive just fine thanks.
Tourism is the only reason we need mainland $. We can look to invest more overseas if necessary once borders open.
Otherwise the state in great position compared to the rabble most are, including Victoria.
Yeah all your industry down there will pull you guys through...
Jack91 is offline
Old 19-08-2020, 07:32 PM   #5430
Franco Cozzo
I keep hearing good things about the produce grown/made in Tassie.
Excellent - I would like to eat this, send it my way
Closed Thread
