Evening people,
Can some one enlighten me as to how one gains access to the top of the brake fluid reservoir please? Seems a dumb design to have it hidden under the plastic scuttle cover. Is there a trick to this? Cheers, Max Heazlewood Last edited by TasFocus07; 06-05-2019 at 01:00 AM. Reason: spelling correction |
the plastic shelf above the brake resevior is removable. It has a few press clips along the front and I think you remove wiper arms as well.
#3 | |||
That sounds like a bit of a PIA! I want to fit a pressure bleeder to do the whole system as I'm replacing rotors front and rear along with new pads front and rear. Otherwise i will use my normal one man bleeder fitted with a non return valve. I'm servicing this car for a friend and there is no record of when the fluid was changed. |
