09-06-2018, 12:07 PM | #1 | ||
Guys,
Can the AU XR head lights be removed from the plastic housing, if so, is there a how to do thread? Cheers |
09-06-2018, 07:25 PM | #2 | ||
Next upgraded Mk1 Leopard
28-06-2018, 03:27 PM | #4 | ||
Family XR8s in Grey
The plastic housings usually brittle and just replaced mine bought new housings on ebay and replaced headlights with aftermarket
Take adjuster tabs off old lights and refit lights and new clips cost under $150
2016 FG XR8 Sprint in Smoke 2002 AU3 XR8 in Meteorite "its all grey from now on" |
28-06-2018, 03:37 PM | #5 | |||
#neuteredlyfe
Did you replace the inner (high beam) ones as well? |
28-06-2018, 04:11 PM | #6 | |||
Family XR8s in Grey
1st thing i did was mark the current beam on garage was as reference. No i didnt replace smaller high beam they are good the old outer lights had damaged reflectors placed in vise to press ANGEL EYE LED WHITE HALO RINGED 7 INCH QH H4 HALOGEN UNIVERSAL HEADLIGHT SET search FORD FALCON XR XR6 XR8 HEADLIGHT CLIP XG to AU ebay
2016 FG XR8 Sprint in Smoke 2002 AU3 XR8 in Meteorite "its all grey from now on" Last edited by ScotchanDry; 28-06-2018 at 04:23 PM. Reason: forgot some stuff |
28-06-2018, 05:25 PM | #7 | |||
HUGH JARSE
I'll pop around for you to fix them for me. |
23-12-2018, 11:24 PM | #8 | ||
Anyone had issue with one side headlight dim than the other.changed Parker bolb as was blown changed the head light with no change got me stuffed. really apreasate the help driving me crazy!
24-12-2018, 12:23 PM | #9 | ||
Family XR8s in Grey
I would be checking Earth and cleaning or make new connection
24-12-2018, 12:49 PM | #10 | ||
thanks for ur help.all morning out there thought I'd go over it again the headlight 3 prongs that connect to it the red wire gave few taps came on.so I guess next step is uncliping the 3 wires that go in the back of the plug and solder the wire back in place.finally but did go through taking rubber boot of checked all the wires first was the globe then thought change em around and nothing till next step playing with the wires and bang found it couple taps here there like you mention the earth cleaned them and the plugs with electrical spray and worked on the wires see if any lose.sorry so long but hope this helps somone in the same situation b pasent and long and play around..
25-12-2018, 10:06 PM | #11 | ||
26-12-2018, 11:43 PM | #12 | ||
Good job. Aftermarket light mods will become commonplace as original hella lights dry up. They are getting hard to find.
