Old 29-09-2006, 02:52 AM   #1
v8kev
67 XR Fairmont
Default Engine block identification
Can anyone help me determine what my engine block is please? It is a 302 of somekind I think - maybe 351
The casting number is D2AE-OA
Cant seem to find any info on it??? Can anyone help?????
KEV
v8kev is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2006, 06:03 AM   #2
rag top
rag top's Avatar
I think you might be missing some numbers after the OA.
Does this help:
http://www.mustangsandmore.com/ubb/FordTechData.html
The first two digits indicate year. The letter is the decade;
A = '40s
B = '50s
C = '60s
D = '70s
E = '80s
F = '90s
G = '00s
The third digit designates body line;
A = Ford full size
D = Falcon
E = Escort
F = Pinto, Maverick, Falcon
G = Early Comets, Montego, Cyclone
H = Medium/Heavy Duty Truck
K = Edsel
L = Lincoln Mark VII
M = Mercury
O = Fairlane
R = Capri
S = Thunderbird
T = Pick-up Truck or Bronco
U = Econoline Van
V = Lincoln
W = Cougar
Z = Mustang
{there are actually many more}
The fourth position signifies Engineering group;
A = Chassis
B = Body
E = Engine
If it's a Service Replacement part;
Z = Ford Division
Y = Lincoln-Mercury
X = Original Muscle Parts program
M = Ford Motorsport, SVO, FFRP
The center number, four or more numbers or letters, is the part number.
The A at the end of the number indicates that the part is the first version. If it was revised once, it would be B. If it was revised again, it would be C, and so on. When they run out of letters, it becomes AA, AB, and so on.
So if we decode this number, D1ZZ-6675-C, we come up with the
following:
D1 = 1971 model year.
Z = Mustang.
Z = Ford Division Service Replacement part.
6675 = the group number for oil pans.
C = The third version of this part.
Also, have a look at this discussion here:
http://www.mustangforums.com/archive...1870101-1.html
Old 30-09-2006, 02:34 PM   #3
bartaxr8
bartaxr8's Avatar
KEV
A picture would really help.......................
bartaxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2006, 12:10 PM   #4
v8kev
67 XR Fairmont
Smile oops
Thanks to the guys who replied .... Have discovered it really is a D2AE-CA - which is a 1972 351 ..... The C, really does look like an "O" where the open end of a C is just a tiny thin line (which of course had grease filling it up to complete the look of an "O"
thanks again.
KEV
Old 03-10-2006, 01:43 PM   #5
Paull
P6 LTD
Paull's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For all the hard work performed around paint, trim, engine codes in the Classics section. General all round knwoledge and willingness to impart on others
The casting number is not the whole picture. Have a look at the engine number (stamped above the fuel pump) and then have a read of this site:
http://www.fomoco.com.au/ID.html
Paul
Paull is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2015, 11:35 AM   #6
Magger
Default Re: Engine block identification
What's the engine code for a BF 6 cylinder petrol none turbo?............regards Magger
Magger is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2018, 04:45 PM   #7
stevethomas1975
trying to work out if the XM has a 200ci as asvised when purchased? Has 3 plugs & 3 bolt water pump. Numbers from the block as follows;
ARC1DE 6051A
Or
MC22789
Anyone able to decipher?
Appreciate the feedback.
Has seen a lot of posts regarding the 200ci and some doubters
stevethomas1975 is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2018, 11:38 PM   #8
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
ARC1DE 6051A
Or
MC22789
XM and XP had earlier 200 CID with 4 main bearing cap blocks (3-freeze plugs and 3 bolt water pump).
* 250ci -7 main: 4 bolt water pump and 5 freeze plugs.
* 200ci -7 main: 3 bolt water pump and 5 freeze plugs.
* 200ci -4 main: 3 bolt water pump and 3 freeze plugs.
* 170ci -4 main: 3 bolt water pump, 3 freeze plugs, and a “T” code (or no code).
* 144ci -4 main: 3 bolt water pump, 3 freeze plugs, and an “N” code.
jpd80 is offline   Reply With Quote Multi-Quote with this Post
