28-10-2016, 08:03 PM | #1 | ||
BA XR6 2003
Hey guys my icc unit turns off & on randomly sometime have to give a whack for the screen to turn on sometimes the control works & some it doesnt also power windows tends to drive up like a snail everyone suggested graphite powder is there a fixed solution cheers vitz. Ba xr6 2003
28-10-2016, 09:01 PM | #2 | ||
Graphite powder is the general solution, unless you was to pull out your baileys channels on all windows and clean them manually.
It's possibly that the plugs underneath and at the rear of the ICC are loose. This shouldn't be the case unless it's been previously removed, but it'd be the first thing I'd check. See the instructions for mixer shaft replacement in the tech portal for instructions on how to get to those plugs.
1976 XB Falcon 500 Wagon - BUILD THREAD Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop |
28-10-2016, 09:14 PM | #4 | ||
Armourall for the windows works a treat
My Resume: Current: Alfa Romeo Giulia Quadrifoglio in Vulcano Black MY18 Black WRX STi Spec-R Previous: '16 White FGX XR8 '09 Black FG FPV GT 5th Anniversary '04 Blueprint BA XR8 '97 Mocha Foam EL Fairmont |
28-10-2016, 11:03 PM | #5 | |||
Similar issue I had with Premium ICC on my G220. It would randomly turn / off. There was two options either replace or repair. Repair was 50:50 chance. I had mine repaired, so far so good. Have a look on eBay to get and idea of prices of secondhand ones. You could also ring wrecker to see what price is, they may recommend someone who can fix cheap. Lucky there were many BA's made so there should be plenty of secondhand ones. |
29-10-2016, 02:01 AM | #6 | ||
BA XR6 2003
Thanks guys is true that if icc is unplugged that it goes into a lock mode?
29-10-2016, 08:20 AM | #7 | ||
hi mate i have just removed my icc unit $80 + postage if you need it all in good cond warnie
29-10-2016, 10:44 AM | #8 | |||
Just unplug the battery for a few minutes and then do your work with the ICC. If you read those instructions I mentioned in my first post, you'll see that technically there is an order to it, but I'm not sure how relevant that is now. Personally I've not had trouble this way.
29-10-2016, 12:13 PM | #9 | ||
BA XR6 2003
Cool will give it a crack cheers everyone ✌
