16-06-2014, 02:36 PM | #1 | ||
Gift from me because its so hard to find good info:
Name "ShortName" "ModeAndPID" "Equation" "Min Value" "Max Value" "Units" "Header" Accelerator Pedal Position "ACC PEDAL POS" "22032b" "A/2" "%" Air Cond Compressor State "AIR COND" "22099b" "A" Battery Age "BATT AGE" "224027" "((A*256)+B)" "Days" "726" Battery Charge "BATT%" "224028" "A/256*100" "%" "726" Battery Temperature "BATT Temp" "224029" "A-40" "°C" "726" Brake Fluid line Hydraulic Pressure "BFLHP" "222b0d" "A" "kpa" Catalyst Temperature "CAT TEMP" "22f43c" "((A*256)+B)-40" "°C" Clutch A Slip "CLUTCH A SLIP" "221ebb" "((A*256)+B)*(1/4)" "RPM" Clutch B Slip "CLUTCH B SLIP" "221ebc" "((A*256)+B)*(1/4)" "RPM" Clutch Open "CLUTCH STATE" "221eA0" "A&256" Engine Total Distance "ENG DIST" "22dd01" "((A*256)+B)" "KM" Fuel Level "FUEL LEVEL" "22f42f" "A/256*100" "%" Fuel Pump Pressure Desired "FUEL PSI DESIRED" "2203dc" "((256*A)+b)*10*.145" "PSI" Gear Commanded by Output State "GEAR" "221e12" "A" "Gear" In Car Temperature "INCARTEMP" "22dd04" "A/8" "°C" "726" In Gear "IN GEAR" "221e04" "A" Inlet Air Temperature Fault "INLET TEMP" "220700" "A" Lateral Angle "LAT °" "222b0c" "SIGNED(A)" "°" "ABS" Lateral G "LAT G" "222b11" "((signed(A)*256)+B)*0.02" "g" "ABS" Learned Relative Octane Adjust "OCTANE ADJ" "2203E8" "A/256*100" "%" Longitude G "LONG G" "222b0c" "((signed(A)*256)+B)*0.02" "g" "ABS" Max Diff between TP1 and TP2 "DIFF TP1 TP2" "2203A7" "A" "°" Steering Wheel Angle "STWHEEL" "223302" "((signed(A)*256+b)/10-780" "°" "ABS" Throttle Position (Desired) "TP D" "22091a" "((A*256)+B)*(100/8192)" "°" Torque Control Request "TORQ CON" "2203AF" "A" Trans Axle Gear Ratio Measured "GEAR RATIO" "221e16" "((A*256)+B)/4096" ":1" Transmission Gear Engaged "GEAR ENGAGED" "221e1f" "A" "Gear" Transmission Gear Mode "GEAR MODE" "221e23" "A" "Mode" Transmission Temperature "Trans" "221E1C" "(((SIGNED(A)*256)+B)*(9/8)+320)/10" -40 260 "°C" "TCM" ABS Wheel Speed 1 "ABS RFW" "222b06" "A" "KM/H" "ABS" ABS Wheel Speed 2 "ABS LFW" "222b07" "A" "KM/H" "ABS" ABS Wheel Speed 3 "ABS RRW" "222b08" "A" "KM/H" "ABS" ABS Wheel Speed 4 "ABS LRW" "222b09" "A" "KM/H" "ABS" Engine Knock "Knock" "2203ec" "signed(A)/2" "°" |
16-06-2014, 02:50 PM | #2 | ||
Be an even better gift if I had a decoding handbook so I could make head or tail of all that gibberish.....
Craig H
Labels are for jars, not for people. Life is a journey, not a destination. ~~~~~~~~~~~~~~ Daily: 2013 FGII EcoLPi in Winter White Play: 2015 FG X XR8 in Emperor Show' N Shine thread Gone, but not forgotten: 2015 SZII petrol Titanium Territory in Emperor |
16-06-2014, 04:04 PM | #3 | ||
Lol, sorry, just copy it to Excel and you can see it easier, it is already in a format that can be saved as a csv format for torque app.
Example: Long name:Accelerator Pedal Position Short Name"ACC PEDAL POS" PID "22032b" Equation "A/2" Unit "%" Header = blank |
