Old 07-04-2014, 08:23 PM   #1
steveyba
BS 60 RV
steveyba's Avatar
Default EL or EF WAGON
Hi there,
I've just bought a 1996 el wagon with a few issues,
paid $700 bucks for it
I would like to know if this is a el or ef wagon for starters as my dad had a ef wagon same year model
first issue is that the rear doors don't open from outside and the drivers rear has child lock on as well
is there a way from inside the cabin to open it
it has duel fuel but when trying to put gas in it or does not want to fill up unknown if its the connection or the pump connection
if there any other things I should be looking for all the help is welcomed very much
If life is passing you by,it maybe due to buying that holden that your misses said not to buy
steveyba is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2014, 03:33 AM   #2
zabatron
Default Re: EL or EF WAGON
To find out if it is an Ef or El wagon,just read what it says on the vin plates.Also,Ef will have a coil pack where as an El will have a distributor.
zabatron is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2014, 08:09 AM   #3
LTDHO
The one and only
LTDHO's Avatar
As said, popping the bonnet will confirm what it is.
Also there will be a few smaller differences around the car, but compliance plate is the most accurate.
Seems like you have a bit a work ahead of you.
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2014, 11:25 PM   #4
steveyba
BS 60 RV
steveyba's Avatar
Yep Definetly had a fair bit to do
Cheers guys for help
Old 12-04-2014, 01:51 AM   #5
zabatron
Is it an Ef or El?
Old 15-04-2014, 08:31 AM   #6
naughtyfalcon
with the back door, you can undo the hinges and carefully open it by moving it till it lifts, i had to do this with an xf
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2014, 02:29 PM   #7
naughtyfalcon
any results for this?
2000 AU Wagon
