Old 13-01-2014, 04:50 PM   #1
brad24
brad24's Avatar
Default watering down a drag strip
A first for me, watering dowm a drag strip,
Perth was 43 degrees last Saturday at the top fuel meeting
'68 XT Fairmont, 9.48@141.6
'69 Capri
'95 triumph speed triple, '10 Fat Bob
My XT Fairmont
http://www.fordforums.com.au/showthread.php?t=11298079
My capri track car
http://www.fordforums.com.au/showthread.php?t=11492523
brad24 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2014, 05:41 PM   #2
LyleXR8
Default Re: watering down a drag strip
Hot track cool air is ideal but too hot will melt soft compound tyres and if the lower end of the track if it's asphalt and it bleeds you'll have cars in the wall as well as destroy the track
LyleXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2014, 06:28 PM   #3
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
have never seen one watered down but agree that too hot a track and it becomes slippery
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2014, 02:32 PM   #4
perthfggsute
i was at that meeting too,i just thought they were washing the track as its top fuel meet etc,but from what has been said there may be an optimum temp for the track to be good for those monsters to run well and safely.
december 2010 fg gs 315 ute
Tuned by Monsta Torque
395.2 KW
610 NM
3.07 diff ratio (changed from original 3.73)
6 spot brembo's on the front
3 inch manta cat back exhaust with X piece
6 speed manual
k & n air filter
rear calipers painted red
debadged stripes etc removed
perthfggsute is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2014, 12:25 AM   #5
Work Horse
Budget Racer
Work Horse's Avatar
Motorplex needs to get with the program!
"Track has a proprietary 'Track Cooling System' that is unique to the drag racing industry. This track cooling system lies in the concrete launch pad and circulates chilled water from a pair of 12,000 gallon underground tanks through over 15,000 foot of lines in the launch pad. The cooled area is 200' long; 40' behind the starting line to 160' past the start. Track temperature probes in the concrete, as well as surface reading show temperature reductions between 15-25 degrees."
I Sh*% you not!
http://www.bandimere.com/services/trackFacts.php
12.1@112Mph 285rwkw on n2o Cleveland Power
Work Horse is offline   Reply With Quote Multi-Quote with this Post
