Hi fellas dunno if this thread has been on before so here goes.Have got a gt40 tubular manifold pulled the explorer off,done all the plumbin and found out it wouldnt fit because it sits on the heater pipes that run down the side of the lower manifold,anyone got any ideas!! Freddy
#2 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
Would one of the Phenolic (spellin) spacers lift it enough to clear ?
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
Hi woosha it had an 1\2" spacer on it, wouldnt fit it under the bonnet with a higher spacer dont think! Thanks for your reply,Freddy
not here much anymore
Can you adjust the hoses at all? I'm also curious as to how/where you got the manifold, wouldnt mind one for my ute.
2024 F150 XLT
Pro Street Au Ute
Do you have aftermarket rocker covers on it. when i put my au motor in my eb i put sheet metal rocker covers on and the plenum wouldn't fit without a 1in spacer, fits under the eb bonnet no probs. throw standard covers on if this is the issue and it should clear.
