Man are theese guys cheap I decided to give the ute a bit of spruce up just running bit crappy and the sensors are 11 years old.
already did the coilpacks,plugs leads and camshaft synchronizer/sensor Anyway got me the TPS,airflowmeter, crankshaft position sensor and idler motor for 280 with shipping thats a pretty cheap tuneup in my books and i din't even get the real elcheapo bits so I'm pretty stiked. |
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
Are they only in Vic?
UK
#3 | |||
not here much anymore
RAM 1500
Boza, do you reckon you could post up the rockauto part numbers for the stuff you got? I wouldnt mind having some of this stuff in the shed for when the time comes.
RAM 1500
Iac (idler motor)STANDARD MOTOR PRODUCTS Part # AC158
tps (throttle position sensor) DELPHI Part # SS10387 air flow meter MOTORCRAFT Part # AFLS155 {#XF2Z12B579ABRM** AJ03-13215, XF2F-12B579-AA Crankshaft position sensor STANDARD MOTOR PRODUCTS Part # PC350 All this is 289.39 landed in australia |
Excellent, thankyou!
RAM 1500
#7 | |||
#8 | |||
RAM 1500
#9 | |||
Theese aren't exactly performance parts just more like maintenance parts
is it only v8 stuff? im guessing so as the i6 from the falcon isnt used in america but wondering if they have stuff for 6's aswell
