01-04-2010, 11:53 AM | #91 | |||
Critical Thinker
If I was to relocate the cooler to the battery area as you mention, I would need a different cooler type. More pipe work, more cost, not much extra gain. The breathing is the weakest link at the moment. The car is trying to exhale thru a straw. So I need to get a 3" mandrel system made up. Sorry to go OT fellas. If you wanna know more, post in my build thread or PM me.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
02-10-2010, 11:24 PM | #92 | ||
'06 Ford Territory Turbo
Any further updates on the intake there Matt?
02-10-2010, 11:38 PM | #93 | ||
my one, eventually, i had to give the fibre glass one back, but i made measurments etc to get it made out of stainless steel also need to get some more pipe, but i will get it done soon enough
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
04-10-2010, 11:49 PM | #94 | ||
Hey guys im new to this site just reading over people mods etc, i have a 2001 AU II XR6 running the standard airbox cleaner etc that came factory built, with the air intake pipe between the bonnet and the body of the car. Would changing that to a pod increase performance a noticeable amount or is it not worth the hassle.
05-10-2010, 12:14 AM | #95 | ||
Out of curiosity I did the AU1.5 VCT Ghia to see if it really made a difference. Being a cheap, tight, stingy bugga and not a big fan of Pod filters I figured I could do it really cheap while not having if flopping around under the bonnet - heres how I did it -
Remove airbox lid and solid pipe from flexi pipe. Remove rubber adaptor from the air box lid, screw down to a piece of timber, run a 3" (75mm) hole saw through it. clean up saw cut and remount onto airbox lid. Get a 45 degree alloy 3" pipe - cut exactly half way around the bend. Insert into adaptor with a slight upward angle. Look down the solid pipe form the flexi pipe end - you will see a definate point where the taper from 55mm to 80mm ends - cut off the pipe at this point and throw away the small end (the bit that used to plug into the airbox). smooth out the seam ridges on the outside of the intake pipe (you will see what I mean) to make sure the silicone pipe can seal. Stretch some 3" (75mm) silicone pipe over the outside of the rigid pipe - its tight but it can be done. Slip other end over the alloy pipe in the airbox, clip airbox lid back on, slip flexi hose back on, bolt down intake pipe to original mount over left hand shockie - pivot alloy pipe around until you get good smooth angles when mounted, tighten clamps. All done using 1 45 degree pipe, a 75mm clamp and some silicone hose (don't need to use that much, just what I could scrounge and havn't gotten around to trimming down yet... The partial (ie still using flat panel filter) conversion I have done has not increased the induction noise, lets the VCT spin a little more freely and holds hwy speeds with marginally less throttle angle with no apreciable reduction in lower range torque (by my highly scientific bumometer anyway) - as to fuel economy it will take a few weeks to guage that. Will tidy it up if I decide to leave it on. Cheers James |
05-10-2010, 10:23 AM | #96 | ||
Miami Pilot
Here's mine:
Modified BA XR8 SS inductions snorkel feeding into G&D box, then stock tubing to TB (with wheel cap instead of curly pipe section off the side).
05-10-2010, 10:58 AM | #97 | ||
looks good
05-10-2010, 11:49 AM | #98 | ||
My AU111 XR8 motor in a Mustang
Custom stainless intake made by building a box on to fit on top of the lower intake manifold. Took all the sensors off the origional intake and put them in similar places, kept the intake runners the same length as the origional. My theory was the intake is only an air delivery box, not an air/fuel delivery so providing the airflow and temp sensors can take the right readings then the intake can be any shape you want it to be. Works real good. Last edited by voluntary; 21-03-2016 at 10:07 AM. |
05-10-2010, 12:15 PM | #99 | ||
Still try'n to learn to resize pics.
05-10-2010, 02:03 PM | #100 | ||
Are the Supercars on yet?
I'm getting mine done this weekend. SS bigmouth, and tubing bent up to replace the original piping from the box to the throttle body. will post pics
A Ford win is a good win! V8 dreamteam 1st: 2012, 2021 2nd: 2015, 2016, 2020, 2022, 2023 3rd: 2014, 2018, 2019 |
05-10-2010, 03:13 PM | #101 | |||
rexnet
that looks mental!!! also re. posting pictures if you open a photo bucket and use the IMG code life will be alot easier ;) |
05-10-2010, 11:04 PM | #102 | ||
SEE IF THIS PIC COME OUT BETTER - XR8 220kw crank trigger.
05-10-2010, 11:07 PM | #103 | ||
rexnet
thats epic!!!!
07-10-2010, 02:34 PM | #104 | ||
Former BTIKD
Sorry but I had to fly the flag for us LPG folk
07-10-2010, 04:11 PM | #105 | ||
^^ that's certainly interesting...
07-10-2010, 05:47 PM | #106 | |||
Just another mock-up..
LOVE IT!!!!!
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
08-10-2010, 02:24 PM | #107 | ||
Well i joined the 3 inch club today :P No Pun intended
$9 from my work (supercheap) for a 76mm piece of intercooler pipe. Bargain!! Some Silicon and a hose clamp later and shes done. Here are the pictures: I'm also flying the LPG flag GasOlane Cheers Jason
WANTED: MOMO Metallic blue steering wheel and Manual gearknob! PM Please!!
Stevo _____________________________________ 05/2000 AUII XR6 5sp|Pacemaker 4480 Competition Headers|Lukey catback|Tickford Azzuro's|Impco LPG Conversion |
12-10-2010, 04:27 PM | #108 | ||
I have also put a three inch pipe in today on my AU II. and i fitted a pod filter in the stock Airbox,
i'll send pics soon once i know how. first i put the 3 inch stainless steel pipe, noticed a small improvment in throttle response. then i put the pod filter in the Stock Airbox the next day not much differance but little better, i am using a cheap pod for now will get K&N pod filter in the next couple of days thanks for the ideas everyone SILVA |
13-10-2010, 12:49 AM | #109 | ||
I drive way too much...
Pics or it never happened :p
An easy way is to hit up photobucket.com then grabbing your image link and whacking it between [IMG] these IMG tags [/IMG]
AUIII Straight LPG Done: BA XR6T Snorkel, K&N Panel Filter, EL Belt Cover, 2.5" Exhaust To Come: Extractors, Tran. Cooler, Lowering, High-flow Cat |
13-10-2010, 09:39 AM | #110 | ||
pics or ban
13-10-2010, 09:46 AM | #111 | ||
They have the IMG Link ready to go on photobucket,
Copy and paste Cheers Jason
23-10-2010, 07:40 PM | #112 | ||
This is mine. Just got finished today. I got it done at the same place as my exhuast.
Cost me way too much SS bigmouth, 3" tubing, Lukey Air filter. And it's dual fuel
23-10-2010, 07:56 PM | #113 | ||
Rob
Nice mate, how much did they charge to do the piping?
99 liquid silver AU Classic -Sold
Supercharged Nissan 350z 280rwkw Blueprint series 3 AU V8 manual |
23-10-2010, 08:01 PM | #114 | ||
About 230 i think. And pretty sure that would include a few hours of labour and the filter. SS bigmouth was the most costly thing out of all of it
23-10-2010, 08:02 PM | #115 | ||
Rob
dam... oh well it looks nice ;)
23-10-2010, 08:03 PM | #116 | ||
That sure is a lil pricey, is it mild steel, alloy or stainless pipe
23-10-2010, 08:07 PM | #117 | ||
Just normal exhuast pipe. Yeah certainly was pricey, but being single with little expenses it's ok with me. Only problem is it does touch the fluffy stuff under the bonnet, and will be fun trying to get the filter out with no flexible parts.
23-10-2010, 08:08 PM | #118 | ||
would the normal exhuast pipe get hotter then say alloy or stainless
