Old 07-12-2009, 11:29 PM   #1
TK-421
Default AU 1 Power window conversion.
I have a couple of issue's with the au! three window winder mechanism clips keep detaching from the windows when wound down. What is the best fix?
When i removed the drivers door trim the snipper button was not attached to anything, not sure where the missing rod attaches to.
Lastly being a Forte with manual winders i would like to add power windows in the front doors atleast, if i add the motor and new door loom is it difficult in joining to the under dash wiring?
thanks.
TK-421 is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2009, 09:02 PM   #2
Stav
Smile
Stav's Avatar
You need a silicone lubricant for the the wondow rubber and then head off to a panel beater supply shop for some special silicone glue.Cheers.
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 04-01-2010, 06:41 PM   #3
TK-421
Originally Posted by EF4.0
bump
i've got a rego inspection tomorrow and no snipper button/rod, can anyone point to what it conects to in the door? also when the car is locked with the remote it sounds the horn and doesnt lock.
Old 05-01-2010, 03:09 AM   #4
blownv8au
Pro Street Au Ute
blownv8au's Avatar
bump
firstly with the remote sounding the horn and not locking, don't take it with you take it off you key ring if its not there it doesn't have to work. now with the picture your showing i assume your talking about the red one, if so its the one for the button on the door trim if thats not the one you mean then you may have to explain further but there should be 2 one for the lock barrel and the other for actual lock button and you seem to have both in the pic.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
