Old 06-12-2009, 02:57 AM   #1
amiers
Default A/C drain tube
where is the A/C drain tube inside the car? i can see it in the engine bay, but cant find it inside. i went a bit quick around a left hander today : and felt abit of cold water on my left foot! so i assume the tube has popped off inside
amiers is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2009, 09:42 AM   #2
DW260
DW260's Avatar
Not sure about the A/C, but have you checked the spot-welds below the windscreen washer motor?
I siliconed mine up not long ago and haven't had any water droplets land on my feet since.
FPV GS Ute #370/Brembo brakes
DW260 is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2009, 02:16 PM   #3
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Was thinking same thing.
amiers, Was it or had it been raining?
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2009, 08:26 PM   #4
amiers
no rain. but did wash the car in the morning. checked today after driving and the normal amount of water was coming out of the drain under the car. it was only a drop or 2 inside the other day but it was icey cold. mind you i went around the corner very quick.!
Old 06-12-2009, 08:40 PM   #5
DW260
DW260's Avatar
It's worth a check, I only noticed mine after a wash too.
Old 06-12-2009, 08:57 PM   #6
bingoTE50
Steve
bingoTE50's Avatar
Stick some wire up the drain tube it may be partially blocked and backing up the condensate( water).Easy fix first.
Currently no Fords . 2005 Statesman International 5.7, Mazda 2 and a Hilux.
Former Fords: 2010 Ford Escape 2007 BF11 GT, TE50 Series 1 ,AU V8 One Tonner ,EL Falcon Wagon, ED Fairmont , EB Falcon Series 1. Mk 2 Cortina
Company Fords : 3 BA Falcons , EB 11 Falcon Wagon , Ford F350 351 V8.
bingoTE50 is offline   Reply With Quote Multi-Quote with this Post
