![]() Join Date: Dec 2004
ENGINE
1. 500 bhp (372 kW) @ 5600 rpm (60.4 bhp/liter); 525 lb.-ft. (712 Nm) @ 4200 rpm 2. 10-cylinder 90-degree V-type, liquid-cooled, 505 cubic inches (8277 cc) 3. 356-T6 aluminum alloy block with cast-iron liners, aluminum alloy cylinder heads 4. Bore x Stroke: 4.03 inches x 3.96 inches (102.4 x 100.6) 5. Two pushrod-actuated overhead valves per cylinder with roller-type hydraulic lifters 6. Sequential, multi-port electronic fuel injection with individual runners 7. Compression Ratio: 9.6:1 8. Max Engine Speed: 6000 rpm 9. Fuel Requirement: Unleaded premium, 93 octane (R+M/2) 10. Oil System: Dry Sump; takes 8 quarts Mobil1 10W30 Synthetic 11. Cooling System: Twin aluminum radiators mounted atop engine intake manifolds, force-fed from front-mounted, belt-driven turbine fan. 12. Takes 11 quarts of antifreeze. 13. Exhaust System: Equal-length tubular stainless steel headers with dual collectors and central rear outlets SUSPENSION: Front: Outboard, single-sided parallel upper and lower control arms made from polished billet aluminum. Mounted via ball joint to aluminum steering uprights and hubs. Five degrees caster. Single, fully adjustable centrally located coil-over damper ( 2.25-inch coil with adjustable spring perch); pullrod and rocker-actuated mono linkage. Center-lock racing-style hubs. Rear: Hand-fabricated box-section steel inboard swing arms, incorporating "hydral-link" lockable recirculating hydraulic circuit parking stand. Single fully adjustable centrally located Koni coil-over damper ( 2.25-inch coil with adjustable spring perch); pushrod and rocker-actuated mono linkage. Center-lock racing-style hubs BRAKES: Front: 20-inch perimeter-mounted drilled machined stainless steel rotors, one per wheel. Two four-piston fixed aluminum calipers per wheel (16 pistons total), custom designed. Blue anodized caliper finish. Hand-activated. Rear: 20-inch perimeter-mounted drilled cast-iron rotors, one per wheel. One four-piston fixed aluminum caliper per wheel (8 pistons total), custom designed. Blue anodized caliper finish. Foot-activated. The Tomahawk is a Viper V-10 based motorcycle, a 500 horsepower engine with four wheels beneath it. Chrysler will be selling the original Tomahawk concept and nine replicas through Neiman Marcus, for up to $555,000 each. The motorcycles cannot be licensed, so they cannot be legally driven on public roads. A Chrysler spokesman told Reuters they were meant as rolling sculptures. Rumors had the Tomahawk selling for under $200,000, most likely at a loss or breakeven price, for publicity purposes - but still fully drivable. Wolfgang Bernhard, Chrysler's not particularly respected first mate, was said to be enthusiastic about that project, so much so that hundreds were projected to be built at under $200,000 each. They reportedly cost Chrysler over $100,000 to build (admittedly the work is outsourced). The Dodge Tomahawk can reach 60 miles an hour in about 2.5 seconds, and has a theoretical top speed of nearly 400 mph. Each pair of wheels is separated by a few inches and each wheel has an independent suspension. Bernhard said four wheels were necessary to handle the power from the engine. The Tomahawk remains on display at auto shows - though well out of reach of the general public, elevated on a special display. PERFORMANCE: 0-60 mph: 2.5 seconds (est.) Top Speed: 300+ mph (est.) DIMENSIONS: Length: 102 inches Width: 27.7 inches Height: 36.9 inches Wheelbase: 76 inches Seat Height: 29 inches Weight: 1,500 lbs. Track, Front: 8.75 in Track, Rear: 10 in Weight Dist: 49F/51R Ground Clearance: 3 in Fuel: 3.25 gallons ELECTRICAL SYSTEM: Alternator: 136-amp high-speed Battery: Leak-resistant, maintenance-free 600 CCA Lighting: Headlights consist of 12 five-watt LEDs, front, with beam-modifying optics and masked lenses. Eight LEDs, rear. Headlamps articulate with wheels. TRANSMISSION: Manual, foot-shifted two-speed Aluminum-cased two-speed, sequential racing-style with dog ring, straight-cut gears Gear Ratios: 1st 18:38; 2nd 23:25 Clutch: Double-disc, dry-plate with organic friction materials, hand lever actuated with assist Final drive: Dual 110-link motorcycle-style chains Front Sprockets: 14 teeth Rear Sprockets: 35 teeth Longitudinal, centrally mounted engine, rear-wheel drive layout; monocoque construction, engine is central, stressed member. Body of billet aluminum. Its a MOTORBIKE!!!!! ![]()
4 wheels??? I wonder how it handles? What a monstrosity!
1966 Ford Mustang coupe. 347 stroker, PA reverse manual C4, TCE high stall converter, B&M Pro Ratchet, Edelbrock alum heads, Edelbrock intake manifold, MSD ignition, Holley Street HP 750 CFM carb, gilmer drive, wrapped Hooker Super Comp Headers, dual 3" straight through exhaust, Bilstein shocks, custom springs, full poly suspension, American Racing rims, Open Tracker roller spring saddles and shelby drop. Still to go - Holley Sniper EFI with integrated fuel cell. |
From certain angles it looks like a Honda 250cc.
1965 XP Falcon Deluxe Sedan 1978 XC Falcon Wagon Rallypack 2003 BA Fairlane G220 Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM |
Digging for avatar
I love that "we build it because we can" mentality, but what kind of chains must drive that thing?
was extinct but got better. Last edited by Velociraptor; 24-08-2005 at 02:08 PM. |
LPG > You
Have they found someone with the balls to drive it yet? They were claiming it can go 300mph (480km/h).
LPG Lovers Association President & Member #1. ![]() ![]() |
That was out at the detriot motorshow last year
how stupid
#8 | |||
Awesome and very radical piece of machinery,
Deffinately needs a set of Wheely Bars lol
XY Driv3r
U can always rely on the Americans to build some crazy as bikes.... (OCC and WCC spring to mind!)
Nothin like american muscle between your legs ![]()
bring it on
ugly as sin and does nothing for me, i am sure it would go ok but will it stop like the dodge viper?
Here is the devil-and-all to pay. |
#12 | ||
Posts: n/a
hmmmm wonder if you could fit that engine somhow into a laser.... LOL talk about a sleeper
#13 | ||
Heres another crazy bike
http://www.bikez.com/bike/index.php?bike=20204 Apparently street legal too. |
#14 | |||
I've heard people call motorbike riders "temporary citizens". Bikes like these might just make these people even more temporary.
#15 | |||
Digging for avatar
was extinct but got better. |
#16 | ||
Formally knowen as EBus
lol what a beast, makes the hybossa look like a b!tch....hmmm does it come in dirtbike version?? :1syellow1
Car: :evilking: 91 EB Fairmont 3.9L :evilking: Changes: 5 spd manual Extractors, 2.5in exhaust AMG Quake 17's w/ maxxis rubba Lovelle superlows Cheap a55 Pod Filter Bike: CR250R 05 :evil3: |
#17 | ||
Shoot.
Dodge doesn't seem to like handling.. 20 inch brakes! LOL!
20V Turbo |
#18 | ||
WTF??? its a bike. lol
I was expecting some kind of new age muscle car. lol |
#19 | |||
#20 | |||
my one day build...
#21 | |||
i was talkin about the bike even tho it was interesting to read i think its a stupid idea...that my opinion... and wat u said is ur opinion...just a shame u have to get personal |
#22 | ||
Grinder+Welder = Race car
If anyone has ever started an engine up sitting on the ground, and blipped the throttle, you know that the instant you blipped the throttle on that thing, it'd wind up on its side.... and you'd need an engine hoist top lift the b*astard off your leg...
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear" - Too much power is never enough....Mark Donohue on the Can Am Porsche 917. |
