Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
17-08-2009, 08:37 PM | #1 | ||
just curious what tyre pressure's to run with the standerd 17in sp rubber on the xr8's for drag racing i wss thinking 25psi sound about right?
17-08-2009, 08:41 PM | #2 | ||
Id be looking at 20psi max.
17-08-2009, 09:39 PM | #3 | ||
'69 XW
I'd be very cautious of running too low a pressure in a low profile such as that. You could damage the sidewall and wreck the tyre completely. Average normal pressure is 40psi so personally I would start at about 35 and work from there. In one of my own cars with 245/60/14 tyres I found about 28psi worked OK but have heard of people running down to low 20s. But that's in a higher profile.
18-08-2009, 08:27 PM | #4 | ||
Location: Working, chasing after my daughter and working
Not god running a street tyre lower than about 30psi as any lower it will affect the foot print of the tyre and traction will be reduced.
18-08-2009, 11:23 PM | #5 | |||
I had to drop my 245/40/18 down to 18psi to achieve my 11.91 pass. |
18-08-2009, 11:45 PM | #6 | ||
thanks for that, the tyre's are pretty shot so ill try a few pressure's.
19-08-2009, 11:33 AM | #7 | |||
Absolutely TRUE...no doubt what so ever.....proven time and time again. |
19-08-2009, 06:41 PM | #8 | |||
Look at it this way, drive on the street with too low pressures and you will wear the outside edges of the tyre, run pressures too high, the opposite wear the middle of the tyre, run them at correct pressure even wear, using all of the tyre, therefor maximum traction out of your tyre. |
19-08-2009, 08:00 PM | #9 | |||
19-08-2009, 08:05 PM | #10 | |||
I have done over 30 passes on street tyres and always lowered my pressures. I also have MT streets which I start at 20psi and have been as low as 15psi. Running 15psi I managed a 11.21 with MTs. |
20-08-2009, 11:08 AM | #11 | |||
MT advises not to run below 16psi because it is unsafe... a quick time maybe but the finish line could be a coffin... not sarcastic just an ounce of prevention could save lives. |
