Old 25-10-2008, 10:13 AM   #91
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by twr7cx
Does the 343mm kit retain the E-series offset or take it out to AU-onwards on the front?
What's the deposit for exchange uprights or the extra charge for purchasing outright?
Is the kit for ABS or non-ABS?
We are making a 330mm kit as we speak and it along with the twin piston kit we do retains the e series offset which is why they have been selling well.The uprights can be purchased outright from between $100 to $150 a pair depending what we pay from the wreckers and they can be done in ABS or non ABS .The rotors supplied are with EF EL ABS rings fitted but if an earlier model is needed you have to remove the sensor and fit the early ones on as they have a different amount of teeth.The early model abs rings are about $20 or so each i think.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 25-10-2008, 05:00 PM   #92
twr7cx
Member
twr7cx's Avatar
What about the 343mm kits though? Only really interested in this bad boy, as I figure if I'm going to spend that much on a brake kit, might as well spend the extra and save wondering what if down the line.
Current vehicles: MY12 Land Rover Discovery 4 TDV6, MY03 Land Rover Discovery 2 HSE Td5 off road modified and 1989 Mazda NA MX-5 toy car.
Previously: 1992 Ford EBII Fairmont, 1994 Ford EF Falcon XR6 supercharged, 2003 Ford BA Falcon XR6 Turbo 325rwkw, and 2002 Ford AU3 Falcon XR8 Pursuit 250 270rwkw.
twr7cx is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2008, 10:19 PM   #93
twr7cx
Member
twr7cx's Avatar
Also, any idea what size wheel to get over it? 17" or 18"?
343cm = approximately 13.5" so probably get most 17" wheels over them I would think.
Old 27-10-2008, 09:59 AM   #94
FLOORED
Race Brakes Sydney
FLOORED's Avatar
If you are buying new wheels i would wait until you get the brake kit first to make sure they fit as i would recommend atleast an 18" wheel for this size brake kit.
The 343mm kit would take about the same to make and orders are about 3 weeks wait at the moment but it won't be long before orders aren't done until after Christmas.
MATTHEW PEARCE
Phone 02 9609 1101
Old 19-11-2008, 08:04 PM   #95
Trevor 57
Trevor 57's Avatar
G'day,
what upgrades do you have for an XE?, we use it as a track car at Winton, it currently has standard size DBA slotted rotors, PBR Performace pads, standard callipers and lines, and DOT 5 brake fluid. Standard brakes and pads on the rear.
We would really like to go bigger, but stay within the 15" rims, what do you recomend?
I reserve the right to arm bears
Trevor 57 is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2008, 11:27 AM   #96
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Originally Posted by Big Trev
G'day,
There is a twin piston caliper and 298mm vented disc upgrade and they start from $1500.
MATTHEW PEARCE
Phone 02 9609 1101
Old 29-12-2008, 04:43 PM   #97
twr7cx
Member
twr7cx's Avatar
Front 343mm 2 piece slotted disc with 4 piston AP caliper
When do you open again after Christmas/New Years? I want to order this.
Old 30-12-2008, 08:47 PM   #98
The G6ET Spot
Closing on Wednesday the 24/12/08 and re opening on Monday 12/01/09
The G6ET Spot is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2009, 09:21 AM   #99
twr7cx
Member
twr7cx's Avatar
Dang, 10 days to wait! :-(
Old 09-01-2009, 10:11 PM   #100
FLOORED
Race Brakes Sydney
FLOORED's Avatar
PM me on Monday or even now so i can chase it up on monday thanks mate,I will see if we can get an updated price as everyone has put up there costing.
MATTHEW PEARCE
Phone 02 9609 1101
Old 10-01-2009, 01:18 AM   #101
whitexr
roughneck
whitexr's Avatar
Mate, I believe the BF MKII XR8's and XR6T's came with an upgraded brake package.
Do you know what the upgrade over the BF MKII XR6 was and would you recommend that upgrade or an equivalent that you do?
I'd like to beef up my brakes but I'm not neccessarily looking at a full Brembo kit if you follow me. Slotted front rotors, braided lines and maybe DOT 5 fluid with some good pads?
Thanks
Ego XR6 BF MK 2 NA, 6 spd Auto. Eng mods - Plazmaman air pipe and airbox w/pod filter & xr8 upp snkl, undrdrv, xtrctrs+2.5 hiflo cat & zorst, K & N fltr, BPT Custm tune. 175rwkw. Hndlng mods-1" lwrd Kings sprngs, Whiteline sway bars.
Bling - lwr grill, 19x8 Dark Ardent rims w/ 245 Maxxis, custm tail lites, XR scff plts, XR mats, Shift-i, pod gages, Fairmon chrm boot trim, chrm mirrors, boot de-bdge, red au xr6 side bdges, alloy fuse & comp covers.
To do: Hndlng mods - brake upgrade
whitexr is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2009, 04:04 PM   #102
The G6ET Spot
Thanks
The difference in the brakes on the XR6 and XR6t & XR8 are
XR6 front rotors are 298mm and rears are 316 solid disc
XR6T & XR8 Front rotor 322 and rears 328 ventilated disc
I have these on my BA and the difference in braking was quite amazing. I also put braided lines on mine.
Unless you were going to be doing track days there would no need for anything bigger than this setup.
Give Matt a call on Monday, he is back from holidays then and he will be able to sort you out.
Old 10-01-2009, 09:39 PM   #103
mickyyyy
Is the link below the 322mm that come in the XRT6 & XR8???
http://cgi.ebay.com.au/FALCON-AU-BA-...1%7C240%3A1318
mickyyyy is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2009, 04:20 PM   #104
whitexr
roughneck
whitexr's Avatar
Mate, Thanks for the info. No I won't be doing track work so that should see me out fine.
Old 13-01-2009, 09:47 AM   #105
twr7cx
Member
twr7cx's Avatar
PM sent. Hope the price hasn't risen though, as it's hard enough at the moment to justify spending 4 grand on 4 piston setup for an EF, when BA's etc are offering larger rotors with 4 piston setups for under 3 grand.
Old 13-01-2009, 12:29 PM   #106
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The quote is being done now thanks.I can understand what your saying about price but you just can't compare the kits because the falcon kit is mass produced for a simple bolt on set up and the e series kit has to have uprights modified, 2 piece rotors and brackets made for it to fit because there is simply not much demand to make 50 or so kits but i will do my best to get you a good price.
MATTHEW PEARCE
Phone 02 9609 1101
Old 13-01-2009, 01:40 PM   #107
twr7cx
Member
twr7cx's Avatar
Yeah, understood, if I had my way I'd buy it either way, but these things have to be justified to the financial manager for approval!
Old 13-01-2009, 03:53 PM   #108
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Yeah i missed the part about the "Financial Planner" in our wedding vowels too.Will let you know as soon as i get the price.
MATTHEW PEARCE
Phone 02 9609 1101
Old 13-01-2009, 07:00 PM   #109
Ride
Stay Classy ™
Ride's Avatar
Just wanted to jump in and thank Matt for the Brembo 4 + 4 setup he did for my AU Ghia just before Christmas, had all the gear in within a couple of days and ready to install within a week .. the setup has been fantastic and gave it a good run during a recent Ford cruise ... could outbrake all the T3 TS50's on Tickford premiums without a trouble
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2009, 12:57 PM   #110
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thankyou and much appreciated
MATTHEW PEARCE
Phone 02 9609 1101
Old 15-01-2009, 05:30 PM   #111
twr7cx
Member
twr7cx's Avatar
any update?
Old 16-01-2009, 12:28 PM   #112
FLOORED
Race Brakes Sydney
FLOORED's Avatar
any update?
Yes there now is an updated price and it will be $4400 but as we have still have parts available that had been purchased before everything went up i will do it for the old price of $3950.I will need a deposit of $150 or exchange uprights or you can buy them outright for $150 extra.I will also need a deposit of 50% to start the kit thanks as we only make them when needed.Freight will also be extra.If you are happy with all this let me know what you would like to do.
Front 343mm 2 piece slotted disc with 4 piston AP caliper to suit E series @ $4400
MATTHEW PEARCE
Phone 02 9609 1101
Old 16-01-2009, 07:58 PM   #113
twr7cx
Member
twr7cx's Avatar
Yeah, I'll definitely take it for the $3,950.00. I'll call you Monday morning at work then?
Old 17-01-2009, 09:22 AM   #114
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Thanks
MATTHEW PEARCE
Phone 02 9609 1101
Old 21-03-2009, 08:04 AM   #115
twr7cx
Member
twr7cx's Avatar
Kit arrived Thursday. It is now installed. Pictures:
Installed them last night and replaced my drivers side strut rod to K-frame Nolathane bush that had sheered itself, so didn't finish till 23:00 by which time the old man was asleep so I couldn't bleed them. On my way to do that now though, and then give them a test and get a wheel alignment.
Old 21-03-2009, 10:02 AM   #116
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
Damn they look good!!
If only i could have stretched the $$ that far to get that kit. Maybe one day ;)
STREETBUILT RACING
'99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon!
'78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph!
XH5LWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2009, 03:54 PM   #117
mickyyyy
very sexy brakes dude, let us know how they go
Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc
