#91 | |||
#92 | ||
re
Location: Victoria - where being slow & incompetent is considered being "safe"
ZR1 LT5 was 32 valve dohc per bank. Designed by Lotus, but they had to use Chevys standard bore spacings which meant that the bore/stroke ratio was a bit out.
Re: Yamaha casting Fords alloy heads. IIRC Bill Tuckey's True Blue book said that it was Honda (not that I have anything against Yamaha they have done hot Toyota engines (and the SHO Taurus V6) for ages)
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ Last edited by Rev28K; 18-02-2009 at 06:48 PM. |
#93 | ||
VFII SS UTE
EA to AU not the intec (honda deseign) the head, but ford foundry the design.
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
#94 | |||
Cobblers!
Ego BFII Ghia Titanium Silver E53 X5 4.4i Gunmetal EF XR6. Now retired from active duty. Roses are red. Violets are blue. OS X rocks. Homage to you. |
#95 | |||
Other info, Ford Oz designed a DOHC head for the EA motor, was going to be on the 3.2 motor but only developed similar power to the 3.9 MPEFI so was never used. |
#96 | |||
Oo\===/oO
In 1977 Honda and ford designed it. Honda cast it in japan. Using alloy shipped from australia.
#97 | |||
Oo\===/oO
Funny it is, that xbgs351 was going on about misinformation....
#98 | ||
[QUOTE=xbgs351]We are sure getting into grandfather’s old axe territory here.
XBGS351....i recon if we were to have a pub brawl, you would win. anyway i appreciate your input, especially the first comment...
BMW 125I Kia Seltos Suzuki SV650 FG XR6 (son) |
#99 | |||
Performance moderator
![]() Join Date: Feb 2005
Not to be confused with D series engines.. What was said to me about Cat and Ford wasn't anything to do with thin wall casting... Way back diesel engines where made in three separate sections..Like some motor bike engines today .. They joined forces to design a mono block ..Where crankcase, cylinder section etc was in one cast block to make engines stronger and cheaper to make.... Without being pedantic I'm sure Toyota and other companies have copied .. Not exact copies .. Some of the old Celica motors look very similar to B series Austin motors.. With a little Roots thrown in.. Like the Humber 80 engine.. The old side valve Cadilac and Ford are similar too.. The Caddy has inlet and "exhaust" on centre side of heads..
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. Daily driver GTE FG.. Projects http://www.fordforums.com.au/showthread.php?t=107711 http://www.fordforums.com.au/showthr...8+turbo&page=4 Last edited by ebxr8240; 18-02-2009 at 08:07 PM. |
#100 | ||
Oo\===/oO
Cosworth Did build a Motor on the kent, a variation eventually found its way into the RS200.
The Famous YB cosworths are based on pinto blocks.
#101 | |||
#102 | |||
#103 | |||
The Toyota T series motors look nothing like the Austin B series motors. |
#104 | |||
I didn't mention T series??
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. Daily driver GTE FG.. Projects http://www.fordforums.com.au/showthread.php?t=107711 http://www.fordforums.com.au/showthr...8+turbo&page=4 |
#105 | ||
I always thought it was Yamaha that did the work on the XD heads
just something in the back of my mind This is getting very interesting even if the facts are just old memories and sometimes the memory fades a bit thanks JP or starting it off I do remember reading back in 1963 that there was a Falcon 170 CI with a super charger and fuel injection that was making 200 horse power some thing incredible from a motor that ran 100 HP in standard form Also what about the Falcon of Pritchards in Bayswater in Melbourne that ran a Steam Engine Just getting off track a bit here Does anyone remember Norm Beechys S4 EH Holden they were always painted in a salmon (pinky) colour |
#106 | |||
#107 | |||
#108 | |||
Finally, I had a neighbour who was the Product Engineering Engine Guru for Ford back in the EA development days. The DOHC Engine was going to be used as an XR engine but if you remember back then, the finances were pretty slim and the EA was a bucket of goop and every thing looked terminal. I've always wondered how much of that engine was used as the basis for the Barra Engine... |
#109 | ||
Thanks for the correction aquahead. I knew it was most definitely Honda that did the castings and the raw materials came from Alcoa Aus.
I had a black and white picture of an engineer working with the DOHC EA head somewhere, if I find it, i'll post it up. From memory, it used fingers/buckets and no bearing shells, (same as the SOHC head). |
#110 | ||
yum
xbgs351 you really know your stuff!
2005 LS Focus LX
Nov05 | Manual | Black Sapphire 250,000kms. |
#111 | ||
RS1800 was designed around the Kent engine.. Though much much stronger!!
The alloy block above is similar to 1600 engine.. I remember guys like Brian Hart, Don Halliday bros racing Comaro's around Bay Park at the mount.. His ATS spell was the start of a successful designing career, spent mostly in the US. Founded, and still head of Halliday Technologies and also BLIS technology, and now a engineer for Paul Newman's Champ Car Atlantic team. Also helps nephew Matt and daughter Liz in their respective series. I bought his rally 1600 and latter 2000 Heatway rally engines..
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. Daily driver GTE FG.. Projects http://www.fordforums.com.au/showthread.php?t=107711 http://www.fordforums.com.au/showthr...8+turbo&page=4 Last edited by ebxr8240; 19-02-2009 at 10:34 PM. |
#112 | |||
Peter Car
I was lucky enough to have a look around Fords engine lab a few years ago, and its pretty amazing how they use high speed cameras to view engine internals when they are running on the dyno. The rocker covers have a section removed and replaced with clear perspex, and the camera films what the rocker gear is doing. I think they may even be able to film the combustion chamber to see how the fuel air mix is burning. |
