30-08-2007, 12:27 PM | #1 | ||
Tricolore Tard
I got this in a Ford email newsletter that I dont even remember subscribing too.
BUSTING THE CAR MYTHS With car technology advancing in leaps and bounds since its humble beginnings, we thought it would be a good time to confirm or deny some of the many old mechanics tales that get passed around over the years. MYTH 1: You can drive a long way on empty. TRUTH: Each vehicle will vary, but you should be able to drive five-ten kilometers safely with an “empty” signal showing. It’s not a good idea to do this regularly as it starves your engine of fuel and increases the risk of vapour lock, particularly in the summer months. MYTH 2: You should always warm up your car. TRUTH: The days of leaving a car running for five minutes on a frosty morning are over thankfully, but it’s still a good idea to give your car some time to warm up. This allows the oil to circulate through the engine. MYTH 3: It's best to shift an automatic transmission into neutral at red lights. TRUTH: This myth stems from the idea that keeping the transmission in drive while stepping on the brake wastes fuel and causes unnecessary wear on the driveline. Actual engine wear and fuel loss are minimal.
30-08-2007, 03:59 PM | #2 | |||
Old enough to know better
30-08-2007, 04:28 PM | #3 | ||
Zoom Zoom
The only real reason for a warm up period is not flogging the car when the oil is still warming up as it offers better protection when it's at operating temperature as we all know. The major area that suffers is gearbox, always good not to flog a car out of the parking lot straight away but just give it a few gearchanges to let everything warm up.
2012 Mazda3 MPS
30-08-2007, 04:40 PM | #4 | |||
Tricolore Tard
I didnt write these, just copy and pasted from an email i got, so dont blame me
30-08-2007, 04:47 PM | #5 | ||
Have you ever started a 351 cleveland up & seen how long it takes idleing before the oil comes out the top of the rocker when cold starting???????? :
30-08-2007, 05:23 PM | #6 | ||||
AFF Post NAZI
We are not disputing that old cars may take longer to warm up, but simply, newer cars with technology dont needs as long. :
30-08-2007, 06:07 PM | #7 | |||
ps Fordel...not having a go at you... just this "give time for the oil to circulate" amused me And I do care about V8's!!
30-08-2007, 06:16 PM | #8 | |||
30-08-2007, 06:25 PM | #9 | |||
AFF Post NAZI
i doubt the New GT falcon Engines take as long to warm up as the old V8 engines in the XB falcon? or the XW/Y?
30-08-2007, 06:48 PM | #10 | |||
Tricolore Tard
I care about V8's too and 6's for that matter ;)
31-08-2007, 01:11 AM | #11 | |||
Non-Regular Member
31-08-2007, 10:57 AM | #12 | |||
Supes
Yes I DO drive a Toyota |
31-08-2007, 11:42 AM | #13 | ||
Zoom Zoom
Before this turns into a slog fest, any car running a lower viscosity of oil, especially a fully synthetic will warm up quicker and more evenly and the better oil protects engine in this cooler stage. A Big V8 run on fully synth will be better protected, but then you have additional issues of the oil being too thin for the high pressure high rpm of a big engine and ;eaking out of the seals. The only reasons this has changed nowadays is due to better oils, nothing to do with the size of the engine! Each engine has a correct weight of oil that will protect it for life.
2012 Mazda3 MPS
31-08-2007, 12:08 PM | #14 | |||
AFF Post NAZI
31-08-2007, 01:03 PM | #15 | ||
To avoid arguments I always avoid intangible words like 'better'....
Don't you agree it's a better position? lol |
31-08-2007, 01:06 PM | #16 | |||
AFF Post NAZI
31-08-2007, 02:18 PM | #17 | |||
I see you....
Makes my top 10 posts of 2007.... |
31-08-2007, 02:21 PM | #18 | ||
I see you....
And has now become my signature.....
31-08-2007, 05:48 PM | #19 | ||
No...actually got it. Just ignored it.
14-09-2007, 08:42 PM | #20 | |||
Now let us consider a Zetec vs a Kent. The Zetec is primarily made of aluminium and iron. The Kent is primarily made of iron. The Zetec weighs about 30% less than a Kent, mainly because of the use of aluminium in place of iron. Both motors have a similar volume of oil and coolant to heat. Now aluminium has a Specific Heat Capacity of 0.897 [J/gK)] compared to iron which has a Specific Heat Capacity of 0.450 [J/gK]. As Q = m c ΔT, where Q = heat, m = mass, c = Specific Heat Capacity and ΔT is the change in temperature, it is clear that aluminium takes twices as much heat to warm up a certain amount than iron does. With aluminium having a higher specific capacity than iron by 200%, there is no way that a reduction in engine weight of 30% is going to counteract it. So why not face the facts? Newer technology does not make engines warm up faster, it just makes them less cantankerous to drive when they are not fully warmed up. |
14-09-2007, 09:28 PM | #21 | ||||
AFF Post NAZI
"Its not always about power, The car has to handle Beautifully" Last edited by photn; 14-09-2007 at 09:36 PM. |
14-09-2007, 10:19 PM | #22 | |||
Here is the kindergarten version: Starting with the basic formula Q = m c ΔT We want to calculate the change in temperature (ΔT), so we rearrange the formula to this: ΔT = Q /m c Heat = Q Lets assume that we add 1000 Joules of heat. Mass = m Lets assume that the aluminium and iron weigh 100 grams. Aluminium Specific Heat Capacity = c = 0.897 ΔT = Q /m c = 1000/(100 x 0.897) = 11.15 degrees Celsius Iron Specific Heat Capacity = c = 0.450 ΔT = Q /m c = 1000/(100 x 0.457) = 21.89 degrees Celsius Is that clear enough? Perhaps try wikipedia: http://en.wikipedia.org/wiki/Heat_ca...#Heat_capacity |
14-09-2007, 10:45 PM | #23 | |||
AFF Post NAZI
Much more clearer.. and im sorry that i didnt do Phsyics at school :P
14-09-2007, 10:49 PM | #24 | |||
15-09-2007, 08:56 AM | #25 | ||
the only problem with the formula is the unequal mass.
cast iron is 7800kg per cubic metre aluminium only 2700 per cubic metre |
15-09-2007, 02:27 PM | #26 | ||
Woops!
17-09-2007, 10:41 PM | #27 | |||
18-09-2007, 10:50 AM | #28 | ||
yes i saw that but you didnt use that in the formula, nor did you take into account that the thermal conductivity of aluminium is .50 whilst that of iron is .163. In reality there are many things to consider. metal conductivity, area of material (engine block),
and barrier (wall thickness).Also consider that internal friction is the primary cause of heat and that you have coolant running between the inner and outer walls of the engine block acting to dissipate that heat.So really you have two formulas. One for conductivity arising from internal friction and the other for dissipation from the cooling system doing its job. On that note its completely bewildering to me and i think engine designers are absolute geniuses. |
18-09-2007, 03:12 PM | #29 | ||
Non-Regular Member
Its pretty common knowledge that aluminium engine are faster to warm-up.
