05-05-2007, 04:46 PM | #1 | ||
What are the little things I can do, to make the car run smoother, better and overall more economical without spending a small fortune?
05-05-2007, 04:53 PM | #2 | ||||
AU DIE HARD
OR take out a bank loan and "MODTHECRAPOUTOFIT" and have some fun :
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... .................................................. Quote:
05-05-2007, 04:59 PM | #3 | ||
The Origional, The Best
oh noes, whoosha you gonna give him bad ideas like blowers and exhaust systems.......
Current Mods 2.5" Red Back Exhaust | C2R Grill | Brumby Front Bar & Driving Lights | 18" Optic Blacks | Tickford Intake | Blue Momo Shifter Knob & Wheel | BA Scuff Plates with Ford Metal Inserts Future Mods Lowerage on KingSprings Lows | Engine...Period | Sounds System I Use And Recommend F1 Tyres And Wheels On The Gold Coast Proud Supporter of Beat The Heat (NT)
05-05-2007, 05:16 PM | #4 | ||
Run some combustion chamber cleaner through it. The best one is unfortunately discontinued (AC Delco) but there's others out there. Helped mine a bit a while back.
05-05-2007, 05:18 PM | #5 | ||
Smile
Hmm..the cheapest bang for buck is to drive past the bp ultimate pump, drive past shell premium range of fuel and just get vortex 98 fuel.I have found it the best bang for buck trick.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
05-05-2007, 06:53 PM | #6 | ||
tickford intake $35 K&N filter $100 regular maintenance priceless (sorry had to say that) although it starts to up the price i'd also recomend extractors and a car back system I like the redback 2.5" this will cost you about $800 for the 2 but well worth it
05-05-2007, 07:09 PM | #7 | ||
yeah first on every AU owners list should be the BA XR6T snorkle or tickford one if you can find it.
K&N filter or similar spark plugs and leads, o2 sensor (when needed to be replaced), change oil regularly, check tyre pressure, check battery terminals, check power steering pump for leaks and fix NOW if there is. my economical mods included, BA airbox, tickford snorkle and K&N filter.....this got me from 550-750 at most once though in fuel econ thats with a manual though. now its usually around 500-600kms to a tank. and the rest of my car is stock. goodluck
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
05-05-2007, 07:14 PM | #8 | ||
An o2 sensor has an operating life of approx 100,000 klms, so changing it can often give better running and more fuel efficient engine.
Injectors also get dirty and can give faulty spray patterns which can also affect power and economy, it is recommended injectors get cleaned every 80000-100000 klms
05-05-2007, 08:24 PM | #9 | |||
Its Resonating!
06-05-2007, 08:20 AM | #10 | ||
Blue to the bone!
Damm great tips guys, i am running out to get the K&N air filter right now. I assume i have the Tickford snorkle cause there is a Tickford symbol on mine.
Where should i look for the K&N filter? |
06-05-2007, 12:09 PM | #11 | |||
Posts: n/a
06-05-2007, 12:13 PM | #12 | ||
just change it, you can get them for $55 + postage from ebay, for that you may as well just get a new one, chances are it hasn't been replaced
06-05-2007, 12:35 PM | #13 | ||
FTF Club Moderator
Change your fuel filter as well. Cheap and realatively easy to do.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
06-05-2007, 12:48 PM | #14 | ||
All good tips, also for the cost of a can of throttle body cleaner you can clean the throttle body and idle speed controller
06-05-2007, 03:50 PM | #15 | |||
06-05-2007, 04:45 PM | #16 | ||
this was just listed on ebay http://cgi.ebay.com.au/K-N-Air-Filte...QQcmdZViewItem
it will save you a bit |
07-05-2007, 02:59 PM | #17 | ||
Blue to the bone!
Thanks for that!
19-05-2007, 03:45 AM | #18 | ||
Here's something to try. Using a spray can of the cheapest furniture polish you can find, spray all the door rubbers. Clean off any overspray and leave the doors open for 10/20 minutes, close them up then go for a drive. You will amazed how much quieter the body is. It feels like a luxury limo and also makes you realise how much the body flexes.
19-05-2007, 04:21 AM | #19 | |||
Treasure your balls?
Meteorite T3 TS50 ESS |
