08-02-2007, 05:34 PM | #1 | ||
Hey Guys
My engine light on my dash board is on, I was wondering if anyone has experience this problem? If so what was wrong with the car? how much did it cost to fix? Thanks |
08-02-2007, 06:27 PM | #2 | ||
Could be a million problems. Take it to your local Ford dealer so they can find out the problem. To reset the ECU cost me $45.
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
08-02-2007, 06:36 PM | #3 | ||
2007 Ford Focus Zetec
1) Insert Key (do NOT turn it)
2) Press and hold the Trip-Meter Reset Button on the left indicator leaver 3) While holding the reset button, start your car and continue holding the button. 4) When "TEST" is displayed, Quickly let go of the button and press it 5) Pressing the button will now cycle through some 15 different modes. 1. Gauge Sweep 2. Fill in All LCD 3. Indicator Bulbs 4. ROM level 5. NVM level 6. DTC (Diagnostic Trouble Codes) 7. Road Speed MPH 8. Road Speed KPH 9. Engine Speed RPM 10. Fuel Volume 11. Engine Coolant Temp 12. Battery Voltage 13. ABS fail 14. Electronic Brake Distribution Failure 15. Illumination 16. Crank Sense When you reach DTC, it will display ALL of your recorded diagnostic codes like this DTC#1 XXXX, DTC#2 XXXX. It flicks through this very quickly, and keeps cycling through them. Write them all down and come back with the results. |
08-02-2007, 07:40 PM | #4 | ||
Zoom Zoom
It means the engine is feeling small and it wants you to install another 4 cylinders...
http://www.focusfanatics.com/news/im...03_rs8_006.jpg
2012 Mazda3 MPS
08-02-2007, 09:08 PM | #5 | |||
08-02-2007, 11:28 PM | #6 | ||
Hey Snax....told you to buy my ST! :-)
(AKA - Mikey B) |
08-02-2007, 11:54 PM | #7 | ||
Unfortunately, you've got to take your car to Ford.
I hope its still under warranty. |
09-02-2007, 12:18 AM | #8 | ||
Does that mean effectively with these ecu's you dont need a scan gauge to decipher ecl codes?
09-02-2007, 12:32 AM | #9 | ||
Non-Regular Member
Well you can find out what the problem is but for most things you will need Ford to fix it and to clear the error code.
09-02-2007, 01:10 AM | #10 | ||
Error code doesn't need to be cleared to turn the engine light off.
After the ECU notices the problem has been fixed, it will turn off automatically. I'd get Ford to diagnose the problem, and I'd fix the problem myself, and if I did everything correctly, the engine light should disappear. |
09-02-2007, 10:22 AM | #11 | ||
AFF Post NAZI
It should Still be under Warranty From the Dealer You bought it from... i think they give 3 month or 30day warranty on all cars sold?.....take it back to ware you bought it from in Rockdale and tell them to FIX it...
09-02-2007, 12:11 PM | #12 | ||
Or pull the lamp out...
09-02-2007, 12:14 PM | #13 | |||
09-02-2007, 02:48 PM | #14 | |||
Posts: n/a
