TWiZTiD EA
What ways is this posiable to do with out swaping ecu's
10/89 EA 11 Spac5 Speed, Mpfi, EL XR6 Cam, EF/EL Thermo Fans, EL BBM Intake, Sports Exhurst, ED Bonnet, ED XR6 Boot, Boot Lip, Garnish and Lights, ED Electric Mirrors, Trip Computer, Clear Indicators, EB XR6 Steering Wheel, King Superlows, Monroe GT Shocks and EL GT copy Rims. 15.3 @ 90 mph |
PM me if you want
It is not possible unless you add a chip to change fuel maps for the BBM.
I went from 97rwkw to 88rwkw with a BBM as the top end ran way to rich to make power.
TWiZTiD EA
how did you end up making it shift between runners
PM me if you want
I put in a frequency switcher from Jaycar cost about $35
If you stay below 3,800rpm most of the time then its fine, if you always boot it then your economy will be awful.
now with 3.73 lsd
piggyback computer with aux outputs to control changerover point
thats what i have in mine
g6e turbo |
TWiZTiD EA
ok cause the controler on mine is vacum controled
i hopefully can fix the rich part by running a adjustable fuel reg
#7 | |||
now with 3.73 lsd
g6e turbo |
#8 | |||
now with 3.73 lsd
best way is el comp or like i said above piggyback that way will save u alot of trouble in the future
g6e turbo |
TWiZTiD EA
do you still need all the smartlock crap to piggyback ecu's
#10 | |||
now with 3.73 lsd
g6e turbo |
Custom e-series owner
but do the el computers fit in the ea-ed just slot in
#12 | |||
now with 3.73 lsd
g6e turbo |
#13 | |||
Location: Under the bonnet, trying to keep as clean as above!
so if i was lucky enough to find an EL manual ecu, would i be able to run it in my EBII without the bbm at the moment? then later on down the track install the bbm? |
#14 | |||
now with 3.73 lsd
g6e turbo |
#15 | |||
PM me if you want
#16 | ||
My EB never pinged with BBM and EL ECU.
The EL ECU will plug straight into smartlock EBII/ED. Just got to add all the relevant wires and you're set. Trip computer won't work properly though. |
#17 | ||
with putting the el ecu in my ea, ,i still have to get around the smartlock don't i?
whats the best way to do that? |
#18 | |||
now with 3.73 lsd
g6e turbo |
#19 | ||
Never late with a V8
Im running EF Motors with the BBM Manifolds in both my cars though i havent put EL ECU's in either at this point im getting there slowly
My Rides (Daily)2004 Explorer V8 Limited (Project/Cruiser)XE Fairmont Ghia- 351 Cleveland, Toploader (Work) 2014 Kenworth K200 Aerodyne (Classic) 1969 Mini K, 1340, twin SU's The beginning is near!!! Body by Ford. Soul by NudgE
#20 | |||
E-Series Member
Cheers Sam |
#21 | ||
PM me if you want
Piece of cake to put in, a few wires and tap the tacho wire.
#22 | ||
TWiZTiD EA
I now have the BBM working with the frequency switch setup. It doesnt run rich however the only issue i have is that the idle is high but slowly drops back to 800. It is most likely a vac leak.
One thing i did do is use all the ea sensors.
#23 | ||
PM me if you want
I used all EA sensors and still do no idle problems at all.
It will run rich in the top end, put it on a dyno and you will see it (it caused me to go from 96 to 88 rwkw), otherwise below 3,800rpm economy is good and the occassional boot full does not hurt economy much.
#24 | ||
Tuned @ Pitlane Frankston
BBM = Waste of time.
#25 | ||
^^^unless it's factory.
#26 | |||
Low and Loud
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
#27 | |||
#28 | |||
![]() Join Date: Dec 2004
Thread Tools | |
Display Modes | |
