06-08-2005, 07:01 PM | #1 | ||
they call me Tibbo
Here is a quick tutorial for those that aren't overly confident of tackling the job without pictures
Pop a flat blade screw driver under the cover panel and lift it up and forwards, the cover panel complete with switches will lift up Squeeze the tabs on the connectors until the switches and panel is free from the door trim Using the base of the screwdriver, pop the switch out (sorry for the crappy image) Insert the screwdriver into the side of the switch and gently level the housing over the locating tab on the switch button... Repeat on the other side Here you can see the contact strips, the switch and the housing A close up of the contacts, see the black gunk, we want to remove all that and have nice clean fresh contacts (I only did mine recently so there is no loose debris floating around in the housing. Don't be suprised if you have never dismantled them before to find lint,fluff and dirt in the housing. Tip the housing upside down and tap it all out. A tissue on the end of the screwdriver works well too) All nice and clean, expose some bare metal using the corner of the screwdriver to scrape the contacts To assemble you simply put the contact strips back in the housing ** note there are locating tabs in the housing that line up with the notches on each strip so they will only go in one way. Fit the switch back onto the housing by locating one round tab then wiggling the switch button down into the housing until the other locator pops into place. Then gently push the complete switch into the cover until it clicks, reconnect the loom then try all the windows.. If it is all good refit the cover into the arm rest until it pops into place.
4 users like this post: |
07-08-2005, 09:44 PM | #2 | ||
FTF Club Moderator
Tibbo Success. Thanks for the Tutorial, if it wasnot for this I would of broken something. Anyway thanks.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
07-08-2005, 10:37 PM | #3 | ||
its a good tutorial, its such a common problem with AU's and its such an easy fix.
08-08-2005, 12:23 AM | #4 | ||
Back on the road
Nice work Tibbo, I have been thinking about doing this for about the last 2 years.
I'd be confident to give it a crack now, thanks
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
08-08-2005, 12:34 AM | #5 | ||
DPC PERFORMANCE Race prep
Good to see graet advice as these switches cost an arm and a leg to replace one of my mates showed me how to fix mine its simple process and helpful for forum members
: : i will excell with the knowledge i get on here : : FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria Ford Performance Car ClubFord Performance Car ClubFord Performance Car ClubFord Performance Car Club |
10-08-2005, 08:06 PM | #6 | ||
Afterburner + skids =
What problem does this fix? Switches not working/slowness?
10-08-2005, 08:08 PM | #7 | ||
they call me Tibbo
not working, working sometimes, working from one switch but not the other..
10-08-2005, 08:12 PM | #8 | ||
Ahhhh I see, good job, sounds like just what I needed.
11-08-2005, 08:56 PM | #9 | ||
Digging for avatar
Very good work Tibbo , this should go in the workshop section :
was extinct but got better. |
18-10-2006, 08:55 PM | #10 | ||
BF XR8 in Fantasy
Thanks! This tutorial is exactly what I was looking for.
I didn't actually have to take the whole switch module from the main panel after removing the whole thing from the door trim... I just unclipped the 'see-saw' switch straight away to gain access to the metal pins inside. I couldn't believe how much black 'grease' actually gets built up in there... Anyway, this has saved me a fair bit of money mate, so thankyou again! Cheers! |
18-10-2006, 11:42 PM | #11 | ||
Hi frangga (interesting name)
Got your miners hat on? Welcome to the forums. |
03-02-2007, 07:00 PM | #12 | ||
eec tweaker
i have a problem where the switch gets stuck down in one direction (down or up) (and its not the auto down function!).
any ideas? i've tried bending the little contacts (seems like they provide the spring pressure) to no avail. HELP! |
03-02-2007, 07:24 PM | #13 | |||
they call me Tibbo
They can wear down and eventually not be long enough to reset the button
03-02-2007, 08:06 PM | #14 | ||
eec tweaker
hmm..
they dont seem worn.. and they have some grease on them.. now ive ****** the child lock button, and i cant see a way to put it back in without desoldering the whole button assembly... damn engineers! |
03-02-2007, 08:26 PM | #15 | ||
Its Resonating!
I done this with just a key. Sitting in the ute, waiting for it to stop raining lol...
03-02-2007, 09:30 PM | #16 | ||
Walking with God
Great tutorial Tibbo, cheers!
I agree that it should be in the Technical section, as before long the thread will be buried! PM it to Russ I reckon! GK
03-02-2007, 11:56 PM | #17 | ||
FTF Car Club NSW
now for one on replacing the globes in the window switches??
04-02-2007, 02:22 AM | #18 | ||
Brembo Lover
I was gonna say, replacing the globes would be nice (although they may not be in the low series window switches) because two out of four of my drivers switch panel are dark :(
Mine: 2007 BFII XR6 Turbo in Conquer with Sunroof, BFII Typhoon rims, CarPC, FPV Leather Wheel Hers: 2006 BF Super Pursuit in Vixen |
04-02-2007, 03:09 AM | #19 | ||
Fantastic Plastic
Nice tutorial mate , i'll just add 1 more tip to the list . Also applying a thin smear of vasaline to the contact points stops the contacts from sparking and burning out black ( hence causing the need to rescrape the contact surfaces occasionally ). Although the vaseline aids in dust build up slightly, it prevents contact burnout and the switch will last a lifetime. Ususally its a dry burned contact that will cause more problems than a contact vaselined with heavy dust buildup ;) . cheers
04-02-2007, 11:11 AM | #20 | |||
FTF Club Moderator
http://fordforums.com.au/vbportal/mo...article&id=203
04-02-2007, 11:27 AM | #21 | |||
Audi S3
and if one still doesnt work... swap with one that works from another AU. the owner will never know :hihi::
04-02-2007, 11:28 AM | #22 | ||
FTF Car Club NSW
bugger if Henri can do it it must be piece of p!ss :monkes:
04-02-2007, 08:50 PM | #23 | |||
Audi S3
30-06-2007, 06:02 PM | #24 | ||
innocent bystander
Fantastic - thanks to this tute I fixed my passenger's door this morning in about 10 minutes... my wife is rapt... one of the easiest (and cheapest) car repairs I've ever done. (Certainly easier than repairing the fastglass in an XF Fairmont I used to own).
Thanks Racecraft! Thanks Fordforums! Thanks everyone! |
01-03-2008, 07:00 PM | #25 | ||
bumping this to the top, but thanks so much! cleaned and scraped the gunk off each of the terminals and little plates (getting the master driver side switches open was a bit interesting!) and now all my power windows work A1. i was so down when i was driving it home today (having just picked it up) and realising that my power window switches werent working properly. :(
sure it wont be the last time ford forums comes in handy |
21-07-2009, 05:13 PM | #26 | ||
Worked for me............
Thanks !!!! |
26-09-2009, 04:34 PM | #27 | ||
used this today. works a treat, nice thread
11-10-2009, 11:10 AM | #28 | ||
MoPar man 11
Awesome Awesome Awesome............. Thanks for this
09-02-2011, 01:14 AM | #29 | ||
Was at work when passenger window went intermittant and driver window stopped down. Was raining on / off all day. Lunch break followed instructions and had done in 15 minutes. The inside was full of dog hair, grease and dust and contacts covered black. All cleaned and now works fine. Pictures helped a lot. Thanks for info. Darren
05-07-2012, 09:03 AM | #30 | ||
While trying to fix my au drivers window the glass dropped out of its guides and i am having a problem getting it back in does anyone have any secrets to this problem i dont want to break the glass.
Thanks guys.briggo |
Thread Tools | |
Display Modes | |
