![]() ![]() Join Date: Jan 2014
Although my car is still under warranty, and I get the scheduled 15,000Km services done at a dealer or by a professional mechanic and the log book stamped, I still enjoy doing in-between services and minor repairs myself.
I'd love to hear from other members on what they feel comfortable doing themselves at home. Obviously, a lot depends on your skill set, access to proper tools and equipment and if you have the time or passion. List mechanical maintenance, service and repair tasks (excluding mods) you are confident in doing or have done to your cars if you are not a professional motor mechanic by trade. I'll kick off.... ◦ Change brake rotors / pads / flush brake fluid ◦ Adjust handbrake ◦ Change engine oil and filter ◦ Change spark plugs and coil packs ◦ Tighten manifold bolts ◦ Flush radiator and change coolant ◦ Replace or clean air filter ◦ Change differential oil, power steering fluid ◦ Replace head light bulbs / other globes / fuses ◦ Change drive belt / idler pulley ◦ Clean terminals / change battery ◦ Clean throttle body / inlet piping ◦ Replace PCV valve ◦ Scan and erase engine fault codes ◦ Replace radiator hoses ◦ Clean aircon filter ◦ Change fuel filter ◦ Check and replace wheel bearings ◦ Change windscreen wipers ◦ Replace oxygen sensors ◦ Front wheel alignment / rotate wheels ◦ Replace boot / bonnet struts    |
I have always done my own servicing and repairs on any car I have owned, and the only repairs I won't do are those which I don't have the equipment for:
A/C Regas Wheel Alignment Replacing Tyres I did pay for my Diff Bushes to be replaced last year however at the time I didn't have access to a hoist, whereas I do now. I'm not a Motor Mechanic however I am qualified in small engines so maybe that's why I feel confident enough to have a go. And I should add the advice I have received from other members here has been great. |
Hoon On The Rise
![]() Join Date: Mar 2005
Diff bushes
Ball joints Heater shafts Dual zone conversions All Front / Rear suspension bushes LPG converter stuff (low pressure side) Trans coolers Gaskets Timing belts (other makes) Centre bearings
![]() ![]() FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com |
2 users like this post: |
K Code
Front & Rear brake pads & rotors
Wheel bearings/hubs Spark plugs, coil packs Engine oil & filter Transmission service & diff oil Fuel filters Radiator, hose, Header tanker replacement & coolant flush & change Idler pulleys & drive belt Heater tap The thing we haven't done was the cam synchronizer & harmonic balancer We do just about everything else, take your time and read your workshop manuals |
i do all fluids
all filters and bushes, bearing. brake service, rotors , pads rubbers. head gaskets. motor rebuilds i won,t rebuild gearboxes or diffs. panel repair, have done full resprays have done chassis welding and panel welding, aluminum wheel welding repair (xr6 rims needed repair) fix interior. remove and put back in motors gearbox and diffs. in the old days we set points, tuned carb. timing, plugs etc, all done in the back yard. and it all started when a mechanic ripped me off when i was young, thank you sir,, ive saved thousands! Last edited by Pis-ton broke; 12-07-2016 at 04:23 PM. |
![]() Join Date: Oct 2006
Everything - from trans rebuilds to panel and paint. No problem with skills, tools and equipment but my advancing years and declining health is starting to an adverse impact. Oh and local government's desire to prohibit it and especially things like spray painting that can have environmental air quality issues.
regards Blue |
Bathed In A Yellow Glow
Change the air freshener hanging off the rear vision mirror.
Taking things apart.... I always end up with extra nuts and things when I finish the reassemble..... thats why I get others to do anything more then an oil change (an extra plug... not really) or pads
Washing the car
Changing all fluids Radiator repairs Interior repairs or mods Spark plugs and leads Basic electrics Locks. Anything else I can blame on someone else. |
◦ Adjust handbrake ◦ Change engine oil and filter ◦ Change spark plugs and coil packs ◦ Tighten manifold bolts ◦ Flush radiator and change coolant ◦ Replace or clean air filter ◦ Change differential oil, power steering fluid ◦ Replace head light bulbs / other globes / fuses ◦ Change drive belt / idler pulley ◦ Clean terminals / change battery ◦ Clean throttle body / inlet piping ◦ Replace PCV valve ◦ Scan and erase engine fault codes ◦ Replace radiator hoses ◦ Clean aircon filter ◦ Change fuel filter ◦ Check and replace wheel bearings ◦ Change windscreen wipers ◦ Replace oxygen sensors ◦ Front wheel alignment / rotate wheels ◦ Replace boot / bonnet struts Same as BAXRSIX except for wheel alignment and like aussiblue getting on in years 74 this month, recently fitted oil cooler and dual battery system, and service auto transmission (4 speed BTR). |
i am a diesel fitter by trade (was state railways) even tho I was employed in the vehicles division I worked in many divisions from rolling stock/locomotive to break down crew to small motors (ie gensets n so on) I was also put in to the retrim , body and paint shops for short terms
so generally ill do as much as possible in all areas except where my vehicles are still under warranty or I don't have the equipment to do whats needed then I have the deliver do I go out and purchase the equipment or sent the work out ( and as it turns out ive purchased some quality equipment that ive rarely used for this reason like a mig then whent and got a tig and also went and got a lathe on the same day just coz it was there at right price)
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
#12 | ||
Beaut Ute
Fill wiper wash bottle.
Hose down body. Vacuum carpets. Dust instrument cluster. Blacken tyres. Clean rims. Clean windscreen. Fill gas and petrol tanks. —Leave everything else to my mechanic. ![]()
—Cortina Mark I, Escort Mark 2, XR Falcon 500, XE Falcon 4.1 S-Pack, Laser KC Ghia, EF Falcon GLi, BF XR8 Boss 260 |
4 users like this post: |
![]() Join Date: Dec 2006
My list will be shorter saying what I DONT do...
I pay someone to put in new windscreens. |
5 users like this post: |
#14 | ||
Short list of what I won't do...
Wheel alignment... Air con regas... Glass replacement... Interior trim... Diesel or EFI stuff... The black art of automatic gearboxes... Older cars, I'll happily do just about everything up to and including rebuilding an engine providing I can get a crane off someone to get the motor out. |
#15 | ||
If I have the equipment required or I get a quote so ridiculous that buying the equipment it worth it, then I'll give it a try.
So at this time I'd probably just do (or atleast attempt) anything that doesn't require jacking up or putting the car on hoists. If it can be done with the car on the ground and a fairly bog standard tool box, which pretty much limits it to just the engine, I'll give it a go.
Project/Fun Car - BA MkII Fairlane Ghia
Daily Driver - Volvo V50 2.4 "If in doubt, flat out" - Colin McRae "Horsepower is how fast you hit the wall. Torque is how far you take the wall with you" "Cheap, fast and reliable. Pick Two" |
#16 | |||
After a few eye-watering quotes...mainly all labour as the actual helicoil was only less than twenty bucks...I bit the bullet and got stuck in. Oil cooler moved forward, fumble around getting the entire exhaust off, undo about fifteen 6mm bolts holding the sump on (which undid with that heart-stopping "click!" of a small diameter steel bolt going into alloy), and took the sump into the shop to get it done. $35 for the job. Well worth the effort. |
#17 | ||
Pretty much all the OP says, but not wheel alignment.
Also, stripping down the engine or transmission is not my forte, but I have replaced gear boxes and clutches.
2010 FG XR6 I6 CC Ute, Nitro colour. lsd, sports suspension, Ford 18's fitted with Michelin Primacy 3 ST 245x45x18, MW Quick Shifter, Pacemaker 4500 Extractors, Carbuilders Soundproofing, KPM Street Fighter CAI |
#18 | ||
Yes; air con regas is something , although I have most of the gear, that I now have to get someone else to do for legal, environmental and gas access reasons. But I do have my own wheel alignment tools.
regards Blue |
#19 | ||
I wash my car but I am thinking of outsourcing that job.
#20 | ||
Depends on the car!
The Old Rodeo 4WD ute - Anything The XM Falcon - Anything but the auto The Subaru Forester - Most things, minor repairs to engine, not auto The FGX - Very little at this stage. Modern cars are generally too low and congested to work on without a hoist, more and more special tools are needed, and workshop manuals are expensive and difficult to get. I last removed, rebuilt, and refitted an engine 3 years ago, don't think I want to be doing that again. All starts to get too hard as you get older.
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
#21 | ||
Wirlankarra yanama
Can do everything except gear boxes but I'm getting too old to be bothered crawling under a car, so I pay people to get their hands dirty. I still do basic maintenance, plugs, oil changes and my knowledge is useful keeping mechanics honest. Sucks getting old!
#22 | ||
I'm a qualified mechanic and I CBF doing any work more than changing a flat tyre and checking levels on my daily
I'll pay some one and Malcolm and his mates can pay for part of it at the EOFY
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
Thread Tools | |
Display Modes | |
