Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
#121 | |||
Thanks for the reply Matt, Could you please Pm me a price for the T3 5000 2 piece front, suitable rears, and the Hawk pads, posted to postcode 2533. And just to confirm, this combo would suit the FG GT with the brembo 355/32mm 6pot front and 4pot 330/28mm rear? Could you also please advise on how to pay mate Cheers Paul |
#122 | |||
Race Brakes Sydney
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
#123 | ||
Hi Matt,
Just wondering what the supply situation is for the 6/4 Black Brembo package for an FPV GT R-Spec? Or is it still looking like the best option is to get a set of red ones and have them re-painted black? Cheers, Jim
Currently no V8 in the garage! |
#124 | ||
Race Brakes Sydney
Jim we have no access to any Brembo black ones sorry mate and to get them ordered from brembo would cost a bucket load sorry as they would not be available for the same price we can offer the red ones at. Painting them black is the best option.
MATTHEW PEARCE
#125 | |||
Thanks, Jim
#126 | ||
Race Brakes Sydney
The FG 6/4 kits start from $4500 and go up to $6000. All kits will bolt on and have everything supplied including slotted disc rotors. The options up to the $6000 price include 2 piece front rotors and brake pads that can be used for street and track if need be as it is a common request from customers.We can mix and match your upgrade.
MATTHEW PEARCE
#127 | ||
Hi Matt,
I'm not interested in track work so I'd be after the basic 6/4 setup. Two questions: 1) Are the rotors Brembo and are they the same size that FPV would have provided? 2) Are braided hoses included in the kit? You can pm me if you like. Thanks, Jim
#128 | |||
Race Brakes Sydney
1) Are the rotors Brembo and are they the same size that FPV would have provided? In the kit we do for $4650 we supply DBA T3 slotted rotors front and rear and are the same size as the factory ones. 2) Are braided hoses included in the kit? The $4650 kit above has a full set of goodridge braided lines supplied in them. The $4650 kit is better overall than the starting $4500 kit and is more than adequate for what you want and comes with factory brembo brake pads as well.
MATTHEW PEARCE
#129 | ||
Race Brakes Sydney
We still have Brembo 6 piston 355mm front kits available for the FG from $2150 and for AU11 to BF from $2450.
MATTHEW PEARCE
#130 | ||
SQ Champion
whats the largest rear roto available in 28mm thickness?
EL XR6 TURBO - 451rwkw Territory Ghia TURBO - 319rwkw Australian National Sound Quality Champion - 2004 Victorian Sound Quality Champion - 2004 Australian National Sound Quality Champion - 2006 Australian Sound Quality National Finals - Best of Show 06 Winner Summernats 2007 - Super Tech Winner "Ford Champion" Melb Autosalon 2004 Winner "Ford Champion" Melb Autosalon 2006 |
#131 | ||
Race Brakes Sydney
To suit a handbrake set up on the Ford AU11 to FG is 330mm
MATTHEW PEARCE
#132 | ||
SQ Champion
ok, pric eon theose? are the DBA ones the way to go?
What size is standard rear on the turbo?
#133 | ||
Race Brakes Sydney
You mean the FG XR6T rear? These are just a solid 303mm. What are you trying to do if i may ask?
MATTHEW PEARCE
#134 | ||
SQ Champion
Ford Territory Turbo 2009 model.
I have Brembo callipers already and want to use them. What i would like is 2 x 400mm x 32mm front rotors 2 x 400mm (or 380mm or 355mm) x 26mm rear rotors. If it has to be 330mm ones then that may have to do.
#135 | |||
Race Brakes Sydney
The problem with running calipers on over size rotors is the caliper can foul on the disc and also the brake pad wil sit higher than the disc radius because of the radius of the rotors.
MATTHEW PEARCE
#136 | ||
SQ Champion
ok so 375mm on front and 330 on rear.
Price on rotors only? What size is the standard rear rotor?
#137 | |||
Race Brakes Sydney
For the larger single piston rears fitted they are 328mm x 26mm For a 4 piston rear brembo caliper they are 330mm x 28mm - these are what you will get Before i price you on the rotors the front 375mm are a two piece set up so they have a alloy hat and outer rotor ring and the rear rotor is a 1 piece. Do you want the hat and rotor for the front or just the outer ring and you will make the hats and are you after slotted rotors as i will need to sought this out to try and match them.
MATTHEW PEARCE
#138 | ||
SQ Champion
I need the rotor and hat to mount to territory.
yes i want slotted rotors (prefer cross drilled as wel ubt understand you may not be able to provide) My rears are large single piston brembo (not the 4 piston one) so 328mm x 26mm will be needed.
#139 | |||
Race Brakes Sydney
You will have to make a new bracket or i think the factory terri one was steel so you may be able to modify this one for the front caliper to fit a 378mm disc. I am waiting on prices for the front 378mm rotors and also checking stock but the alloy hats and the rear rotors are available.
MATTHEW PEARCE
#140 | ||
SQ Champion
ok no problem.
Of course i'd love a larger calliper set-up all round but unfortunatly dont have the $$
#141 | ||
Howdy, Can you supply a caliper overhaul kit for the brembos that are on the front of a BA GT-P
Cheers Ed |
#142 | ||
Race Brakes Sydney
Seals are sold at $18 each and dust boots if needed are $35 a pair (sold pairs only)
MATTHEW PEARCE
#143 | ||
Hi Mat
Can you supply and fit a Brembo upgrade for a SZ territory AWD ? 6/4 or 4/4 Thanks |
#144 | ||
Race Brakes Sydney
A 4 piston front kit would need a custom bracket but we can get the brackets for the 6 pot fronts as long as the SZ AWD uses the same bolt up pattern as the F6X set up which then brings me to the fact that you have to modify the top of the upright by grinding two flat spots to allow the bracket and caliper to clear as this is what they had to do to the F6X. A total price with fitting would be a guess at around $6k to $7k but if your in the ball park i can get something firmer for you.
MATTHEW PEARCE
#145 | ||
Also keen on an indicative price for 378mm rotor and hat to suit Fg ute.
I am trying to fit some Z18 brembos up front and want to go bigger than 355 diameter.
2011 Vixen fg turbo ute. Plasmaman cai, pipework, intercooler, surge tank, 044, injectors, 4 inch dump pipe, 5 inch cat. Custom engine tune + zf tune by WRC developments ~20psi boost. |
#146 | |||
Race Brakes Sydney
Depending on what pad surface area you need for the rotor and if you go strap drive or just bolt up will determine price as will a one off set of brackets.
MATTHEW PEARCE
#147 | ||
Hey mate,
Just a quick enquiry. I have purchased an FGX XR8 and seriously considering upgrading to a 6/4 setup what can I utilise from the original setup (rotors) as they are new. And what would be an approximate cost including braided lines. What pads would you recommend that aren't massively aggressive on the rotors and dust like mad (may be impossible to get both but obviously a compromise) track work is a possibility. I would like to upgrade to 2 piece rotors on the front later but don't really want to bin a new set of OE fronts if they will suit the 6's if you know what I mean. Your help would be gretatly appreciated. Cheers Ryan |
#148 | |||
I'm happy to make my own brackets I guess the key factor for the disc selection will be the swept depth of the ~378 mm rotor. My preference would be a fixed 2 piece rather than floating disc. I see there is a listing for an Audi (perhaps TTRS and RS3 ) which runs a 370x32 2 piece rotor all be it with the incorrect 5x112 PCD and smaller centre bore, which may be a potential contender..
#149 | ||||
Race Brakes Sydney
The black Brembo's are very competitive in price compared to the reds at the moment and everything you need including the two piece front and braided lines would cost you $5900. The new 4/1 combo on your car when removed for sale as a complete kit should get you between $2000 to $2500 max. The red Brembo 6/4 kit with the 2 piece dba and the braided is about $6900 Quote:
MATTHEW PEARCE
#150 | |||
Cheers Ryan |
