Rollin
Ok i know if i change any suspension out go warrenty as they can blame almost anything on it so thats out of the question at the moment. But was thinking strut brace. if i can find one will it help with cornering at all ? or just waste of $
GT4.
What do you mean they can blame anything on suspesion? I was under the impression if you change the springs then they can void warranty on the shocks etc. but thats about it! WIll they really void the whole car just for lowered springs??
Candy White GTI
doubt theyd void the entire cars warranty. just suspension as you said.
Rollin
Pretty much what happens is if a few months after lowering your car or fitting coil overs etc. you go into ford with a loose door card (thats due to your harsh suspension not covered)
or come in your left window is loose and rattling (suspension) your engine mount cracks or breaks (harsh cornering take of suspension) you head light blows up (to much harsh knocking due to stiff suspension) i know this sounds all crap but the person i talked to said ford push hard on not modifying and if its anyhting mayjor theyl try andblame any prob on the mods) |
Fiesta Zetec
Strut brace will stop the car flexing on cornering load. The Zetec has one on the front as standard, well it is pretty crappy.
It may make it feel slightly better but dont expect too much. Will help more in the 3 door cars than the 5 doors as the 5 door has a b pillar which helps regidity. I doubt ford can claim anything as a harder ride is unlikley to rattle the car apart or cause components to fail. They can try, but they have to prove that the mod directly caused the component to fail. |
#6 | |||
not here much anymore
You are right but to a point they can only do so much - even if it was your suspension causing i.e. your window to rattle you can still ask for it to be fixed and theoretically they will, or should, try to fix it. Danny, shocks technically dont have a warranty as such cos they're a consumable part - they don't last forever. That said, if your shocks were stuffed after 10,000 kms etc, obviously there would be something wrong with them and therefore they would be require to replace them under warranty. but you couldnt go back after 100,000kms or so and say 'theyre stuffed, gimme new ones'. Would all depend. If anybody is thinking about lowering or changing their suspension setups I would suggest you speak to your local Service Advisor first, that way you will know what's going to happen once you do it, although I think it should be find and they just wont touch the suspension.
RAM 1500
Clio 182 CUP!
Zetec has a strut brace? where?
------------- Steven 'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04) |
GT4.
Good question. I cant see it.....
Clio 182 CUP!
Was almost certain the zetec was just Cosmetics and the ABS
Zetec Screamer....
Ive been through this with my dealer on my Focus. They said that lowering is fine, but as back2thefutura mentioned, the shocks and springs arent covered by warranty anyway coz they are a wear n tear item (except in extreme cases), and new shocks and springs should have their own warranty anyway. But they did go on to mention that if something directly associated with the lowered spring/shock was to wear out prematurely (the example they used was bushings and stock shocks with lower springs), then no they wouldnt be covered by warranty. Only suspension bits and pieces that normally wear and wear quicker now as a result wouldnt be covered.
Im getting a set of H&R springs put on my Foci when i get my springs in a weeks time hopefully. Tom Last edited by chevaps; 25-05-2005 at 03:32 AM. |
Candy White GTI
all fiestas have a sort of strut brace. doesnt connect both suspension pillars. its on the left. black thing :P have a look
#12 | ||
Cant say my local ford dealer has given me any grief with my eibach springs. As it was said above some dealers will be better then others. Might just need to look around abit to find which ones are ok.
I really cant do there here only 1 ford dealer unless i drive 1 hour to melb or geelong. |
#13 | ||
Rollin
Just found out these prices not bad i think
k mac Currently we manufacture Springs (any height required) @ $330 set 4 incl. GST Front uprated Anti-Sway bar $265 Rear Bolt on Bar $245 Front Camber adjuster kit $130 pr Regards |
#14 | ||
Candy White GTI
*drooling* give me one of each
#15 | ||
Panther Black MK6
give me adjust sway bars ,front and rear srtutbrace ,front and rear chassi brace , adjustable shocks (koni yellows) and ill be happy
AP1 on its way In development stage 2 ![]() Carnt wait for the day ,NA all the way ,9000rpm with the top down |
#16 | ||
Just to give you some further info - i had a good chat with my service manager yesterday about this as mods for my Focus are now only a few paychecks away. Basicaly he said it is at the discretion of the dealer whether they choose to void yuor entire warranty or not based on mods, however they would have to have good reason for doing it (i.e. a supercharger/turbo setup etc) and you can take it up with Ford if you feel they're not being fair about it.
But the basic rule is that anything you mod will not be covered (duh I hear you say). Therefore if you put new springs in there and smoething goes wrong, thats not covered, however everything else still is.
RAM 1500
#17 | ||
Rollin
well tax return is going towards this upgrade wooot
#18 | ||
GRRRR.....
I just bought a st of 25mm lowered King springs for $189...... Now just gotta find time to fit them. Sway bars would be nice too.
