Old 14-06-2007, 03:14 PM   #1
bauschy
Default Opinions???
Hey there,
Looking into buying a soarer and don't know alot about em exept they look awsome!!! Was just wonderin what u guy's know/think.
Thanks
bauschy is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 03:25 PM   #2
Nappa
Impressive...
Nappa's Avatar
they seem to be a good cheap way to get into some moderate performance, personally i'm not a fan, just be sure to do lots of homework on imports before purchasing.
2007 WQ Fiesta XR4
Performance Blue with Stripes
Nappa is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 03:27 PM   #3
sleekism
1999 Ford Fairmont Ghia
sleekism's Avatar
Go the V8 version if you can (3UZ-FE) I think it's rated around 220kw and is DOHC the 2JZ version is overated.
sleekism is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 03:33 PM   #4
Rev28K
re
Location: Victoria - where being slow & incompetent is considered being "safe"
It shouldn’t be that hard to get grunt out of the TT Supra engine.
Even if they are slightly over-rated I still think that they are a pretty good engine.
Scuderia Rev: Otto the tow pig - 2007 3.0 litre Coupé, vernünftig schnelle aber kein peilstab, Bathurst 2007 und 2010 zwölf Stunde Gewinner Jaffa the angry ant - mid 70's Honda 市民の, 73 と立方インチ LSD Elle "the body" shell - early 70's Datsun フェアレディ coupe. いい体は彼女の内側、内側と土台を待つ
Rev28K is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 03:44 PM   #5
sleekism
sleekism's Avatar
The 3UZ-FE is the better pick, if you wan't a real straight six go BMW or the good old Ford Aussie Six which has a stronger bottom end and makes huge amounts of torque when turbocharged.
Seeing as your a ricer fan rev28k your obviously biased as I am towards Fords but it is obvious that a lot of vehicles in the ricer scene are overated biggest examples being Hyundai Excels, Nissan Pulsars and non-evo Lancers.
Nissan put better investment into their sixes than Toyota so I know it's cliched but a Nissan RB engine is the better pick but I personally would recommend a SOHC XR6 as they are extremely underated vehicle with a bulletproof bottom end
Old 14-06-2007, 04:12 PM   #6
Powdered Toast Man
Professional Mouse Jockey
Powdered Toast Man's Avatar
Actually I think it's more like 180kw for the V8 especially the earlier ones.
Make sure all the electronics work. Being a high end Toyota/Lexus there is a lot of electronics in them.
I was going to buy one about 5 years ago. Never happened though.
Isuzu MUX for towing horses - currently no Fords in the stable
Time flies like an arrow; fruit flies like a banana. Groucho Marx
Powdered Toast Man is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 04:17 PM   #7
vandrsxr6
Force Fed Fords
vandrsxr6's Avatar
190kw for the V8
207kw for th TT6
BA XR6 TURBO
310rwkw and always chasing more
Now with 6th Gear
RAPID PERFORMANCE
ORSM FORD CRUISER
vandrsxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 04:35 PM   #8
pb02
inconceivable!
pb02's Avatar
The 3.0 litre DOHC sequential twin-turbo 2JZ-GTE engine is actually considered by many to be a better engine than the Nissan RB26DETT.
The 3UZ-FE is a beautiful engine but at the end of the day it depends on what your after. If you want power, the after market for the 2JZ is huge, I know of a few guys that run 9's and don't seem to have too much problems. If you want to cruise around then I would suggest the 3UZ-FE.
pb02 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 04:38 PM   #9
Decadentia
Decadentia's Avatar
Sorry mate but that's a bit misleading.
The V8 has everything you'd want in as far as specs go ( quad cam, SIX bolt mains), can rev and make good power but has been left behind on the aftermarket front.
The 2jz is massively strong, an uprated turbo and an uprated fuel supply will see better than 500 hp on the dyno. Anywhere between 600 and 900 HP have been recorded more than just once on a stock bottom end with an appropriate sized single turbo. There have been 2jz powered cars into the low 10's on stock internal engines (crank/bearings/pistons/rods/head/bolts - maybe revised cam timing), so advocating the v8 to be the pick of the two is kinda misleading.
Just do some research, There are heaps of forums around that deal with 2j powered vehicles, and they'd have better answers for you than I.
Decadentia is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 04:50 PM   #10
Turboconvert
i agree with Decadentia, i dont think the 2jz is underrated really especially incomparison to the v8 verision. my brother is into imports a bit and reading some of his mags and other stories that come thou him, i have good reason to believe that the stock internals will be able to put up with 500 -600hp before you will be considering strengthing the internals (for the most part but not always). i dont know that much about the v8 thou.
Bf xr6 turbo sedan, 6 SP auto, Leather/suede interior
Turboconvert is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 04:56 PM   #11
bauschy
All this stuff is great guys thanks heaps! Looking to go the tt 6, seen a few around but i don't know how reliable they r as far as turbos go?
Old 14-06-2007, 05:01 PM   #12
bauschy
I was going to buy one about 5 years ago. Never happened though.[/QUOTE]
Do u remember what sought of $$$ they were fetchin back then?
Old 14-06-2007, 05:04 PM   #13
Decadentia
Decadentia's Avatar
Truth be known mate the models you'd be looking at would actually have the 1jz engine in them, which probably doesn't quite have the reputation that the 2j has, but is still a capable engine. They're a reliable engine and they have toyota reliability on their side, so not much goes wrong IF everything is sound and as it should be.
As I mentioned, there are forums that deal with the JZ series engines, they were in soarers and aristos, so find a forum that deals specifically with them and they'd be able to help you a bit better.
The V8 model would have the 1uzfe engine in it.
Old 14-06-2007, 05:06 PM   #14
pb02
inconceivable!
pb02's Avatar
Normally they are fairly reliable but, find out as much as you can about the service history. A well kept and serviced one shouldn't give you much problems. If it's been a bit neglected and not serviced regularly then your better off leaving it alone.
Old 14-06-2007, 05:19 PM   #15
Gobes32
Gobes32's Avatar
Guy at the end of my street had a lexus v8 version with twin pipes, may not have been going fast but it sounded terrific. Very throaty rumble.
Gobes32 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 06:15 PM   #16
sleekism
sleekism's Avatar
Exactly! You can be a ricer and a V8 person!
Japan has built some good V8's which are really overlooked in the hoo haa about their turbos if it was me I would go for something different just my opinion.
Old 14-06-2007, 07:32 PM   #17
sexr6tasy
Yeh mate v8s the go if i went rice id go big **** off v8 rice
sexr6tasy is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 07:39 PM   #18
Redrum
Force Fed Fords
Redrum's Avatar
I have driven both V8 and TT version in 92 models. The TT had so much more poke, the V8 was sluggish. Relatively cheap car for what you get. Look for a TTL or similiar, but the issue is, the clocks are quite easily put back, so you don't really know what you are getting. Not many come with LSD, but a few are optioned with reverse cameras, leather etc.
2021 Focus ST-3 Mountune Enhanced
Redrum is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 07:59 PM   #19
irsa76
Snoopping
irsa76's Avatar
The 3UZ-FE is the cruiser spec, the performance versions used the 2JZ-GTE. There are a couple of Aristos with the 2JZ-GTE that are running 13s with just intercooler, exhaust and FCD. The 2J is over engineered since it was always meant for luxury/performance useage. The 3UZ is just as over engineered, can't remember if the twin turbo 3UZ Celica runs stock internals. Word of warning, while fairly cheap to buy, they can be VERY expensive to fix.
irsa76 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 11:18 PM   #20
sleekism
sleekism's Avatar
The 3UZ-FE was a brilliantly designed V8 that gave the Chev and Ford V8's a good run while the 2JZ is a BMW wannabe.
Thread Tools
Display Modes
